Convertible top rear latch not working
Old Mar 11, 2021 | 08:51 AM
sunsetseeker's Avatar
Default Convertible top rear latch not working
I am having problems with my top again. I have already had the lift cylinders rebuilt and now the rear center latch won't work without a little shove on the top. Opening the top, everything works fine. Closing the top, everything works fine until the last step. The top just won't pull down and latch on it's own. Has anyone had this problem? Thanks!!!
Old Mar 11, 2021 | 09:34 AM
Default Re: Convertible top rear latch not working
I can't say that, in eleven years on this forum, I have heard of this (at least, not very often).
The question is, is it the bow latch that is at fault or is it that the bow cylinders are not pushing the bow down far enough for the latch to catch it and grab it?
The top control module will not activate the bow latch until sensors (which I believe would be the rear bow cylinder's sensors) tell the TCM to engage the rear bow latch. This means that either the rear bow is, again, not traveling down far enough to tell the TCM to activate the latch OR the travel sensor on the rear bow cylider is not telling the TCM to activate the latch.
I'd have to read thru the service manual to see the exact sequence that is expected. I've owned three Roadsters over eleven years, and have never had top issues, other than the window falling out; therefore I've never got very far into the sequence. (I know the secrets of keeping the top working - but when I tell people my secrets, they usually disregard them. Like when I tell them how to keep the A/C working for 190,000 miles... )
Old Mar 16, 2021 | 11:10 PM
buford05's Avatar
I have had similar issues but if I reverse the top movement a couple of inches and retry it will latch. I've topped off the hyd reservoir and looked at the linkage and cables and while it is not a consistent problem it is annoying. I've no idea what causes it. Some of the mechanics on here may know.
Old Mar 25, 2021 | 10:52 AM
Do you have the tool to manually lower and raise the top? Maybe that would reset it?
Old Mar 25, 2021 | 10:44 PM
buford05's Avatar
Thanks for the reply. I have the tools but I'm in Florida and the car is in Pa. right now. I'm going to move to Sebring Fl in a few weeks.
Old Aug 8, 2021 | 08:45 AM
Dcwhite67's Avatar
Hey PizzaGuy,
Tell me how to keep my top working. Please
My top work great up to putting top up rear latch won't latch. I push it down a little and then close " D " handle and push down button then rear bow latches.
Thanking you in advance,
Don
281-728-3404
Old Aug 8, 2021 | 09:48 PM
Originally Posted by Dcwhite67
Hey PizzaGuy,
Don
281-728-3404
Hello Don... Have you tried to send pizzaguy a message? Left click on his member name and select the 'send a private message' link. This way he'll get the message and not miss your question.
Old Aug 9, 2021 | 06:02 AM
Dcwhite67's Avatar
Thank you
Moondog
Oct 15, 2020 10:47 AM
hilarushi
Aug 28, 2018 12:33 PM
mike28117
Jul 17, 2015 01:59 PM
73737373
Aug 15, 2014 07:13 PM
tgreen8219
Nov 12, 2013 08:31 AM
