05 Crossfire factory radio connection by harness?
Old Nov 22, 2021 | 10:38 PM
wbs3246's Avatar
Default 05 Crossfire factory radio connection by harness?
Hello!
My first post on this forum. I am getting ready to install a new stereo in my 05 Crossfire Limited Roadster. I disconnected the wiring harness and antenna from the back of the factory unit. There is a second black wire as well. What is the wire I disconnected next to the harness? It is a lot smaller than the antenna wire. This is throwing me for a loop. Not sure if it is part of GPS or if it will be used in the new installation.
Thanks,
William
Old Nov 22, 2021 | 10:41 PM
Default Re: 05 Crossfire factory radio connection by harness?
gps ( assuming you are removing a NAV unit )
Old Nov 22, 2021 | 10:47 PM
wbs3246's Avatar
Thanks for the quick response! Installing a Kenwood, so I assume I would not use this wire and just tuck back in the console? Seems like everything else is straight forward, just got this vehicle.
Thanks
William
Old Nov 22, 2021 | 10:56 PM
wbs3246's Avatar
Thanks
William
Old Nov 23, 2021 | 09:32 AM
Did you get the Kenwood wire harness adapter?
Old Nov 23, 2021 | 09:43 AM
wbs3246's Avatar
I got the correct Metra harness that plugs into the factory Nav Crossfire radio. It has 4 rca plugs for the speakers along with the color coded wires. Reading everything on the forum, it looks like I will be wiring the red to yellow and yellow to red due to Chrysler's specs. The Kenwood radio has its own connector in the back so should be OK. I am also installing a modulator for the satellite radio. Any other advice would be great!
Thanks@
Old Nov 23, 2021 | 11:32 AM
Originally Posted by wbs3246
IAny other advice would be great!
Thanks@
I have some advice: Do not use the RCA outputs. The factory amp was designed to be driven at speaker level; 4V RCA outputs seem to work better than 2V outputs, but the two cars I modded, I found much better audio by using speaker outputs.
Also, do the four channel mod while you are at it, you will thank yourself (and me) later.
Click HERE:
https://www.crossfireforum.org/forum...-channels.html
Old Nov 24, 2021 | 08:22 AM
Thanks@
Sounds like you bought the Metra Harness 70-1786 (RCA plugs). You won't need to swap the Red & Yellow wires. That only happens if you bought Metra Harness 70-1784 (w/o RCA plugs). The 1784 harness is for VW & Audi applications, but can be used on M-B & Crossfire applications if the Red & Yellow wires are swapped. The 1786 harness is an update and it is no longer required to swap the wire colors on M-B & Crossfire applications.
You probably ought to review the attached DIY from Forum Member GregWork. His DIY write-up was one of the most straight-forward I came across regarding hooking up an after-market stereo to the Crossfire. (Note: Not sure what differences exist between the Infinity unit with or without NAV.) The Scosche VW01B wiring harness is identical to the Metra 70-1784 - both have no RCA connectors. Per pizzaguy, these wire harnesses enable you to direct-wire the speakers in the Crossfire.
Klgeorge13
Nov 21, 2015 11:43 AM
flexfanatic
Feb 18, 2013 10:33 PM
ini2ainbows
Jun 19, 2010 08:50 PM
mr_roadster
May 22, 2009 12:57 PM
ruzo
Aug 14, 2005 06:45 PM
