Passenger side seat will not move front or back .
Old May 29, 2023 | 08:36 PM
blhoov11's Avatar
Default Passenger side seat will not move front or back .
Is there a separate seat relay for the passenger seat under the hood? Or could it be the switch on the side of the seat. Respond via my email blhoov11@verizon.net. Does anybody know a good tech. in Pa?
Old May 30, 2023 | 10:11 AM
Default Re: Passenger side seat will not move front or back .
All responses are for all the viewers on this forum, answers to private emails do not help anyone except you.
There is a relay for the seats on the inside face of the firewall.
Old May 30, 2023 | 12:27 PM
There is one seat relay for both seats. Fuse 22 is for driver's seat and fuse 21 is for passenger's seat (the opposite of that in a right hand drive car). If the fuse is OK and the other seat works, I'd suspect the switch or motor.
If both act up at times, replace the relay.
Old May 31, 2023 | 03:36 PM
blhoov11's Avatar
yes, I checked fuses 21 and 22, they are all good, it must be the switch or the motor. I found the seat relay on the firewall in a sealed fuse box, it also appears to be good, I have a switch, that is my next move to replace it, keep you posted, thanks
Old May 31, 2023 | 04:19 PM
That is not the seat relay. The seat relay is behind the lower instrument panel, to the left of the steering column.
blhoov11
Jul 5, 2023 11:35 AM
Grateful
Jul 28, 2019 01:35 PM
bucketlisted
Feb 13, 2018 03:16 PM
DUKE1978
Jul 3, 2008 10:16 AM
dcspride
Jun 15, 2006 09:04 PM
