E19 Recall
Old Jul 1, 2006 | 08:36 AM
Kit and Kat's Avatar
Default E19 Recall
Had an interesting thing happen yesterday. I took the SRT in for its heat sensor etc, and when I took it home the car heated up more than before, oddly it got hotter as I went faster, and the fan sounded louder than the engine...
I stopped and had a tow back to the garage - It appears that the factory reversed the fan blade or maybe the motor...
Hopefully it didn't get too hot !!
Old Jul 1, 2006 | 09:44 AM
VQ35DE's Avatar
Default Re: E19 Recall
So are you saying that this shop visit was to have the E19 update done to your car and it was done? Was it your original fan that did this or the E19 replacement fan?
Old Jul 1, 2006 | 11:11 AM
Hi,
The new sensor relay had been wired in reverse... actually it pretty easy to know the fan sounds louder than the engine...
Old Jul 1, 2006 | 12:20 PM
CrossfireLTD's Avatar
Cool Re: E19 Recall
For the E19 recall...only the cooling fan control module is changed.
Old Jul 1, 2006 | 01:20 PM
That's what I was lead to believe but apparently they changed the whole fitting ...
Old Jul 1, 2006 | 01:49 PM
markr6754's Avatar
Service Procedure (Continued)
8. Install the new fan and motor assembly onto the module frame and tighten the three nuts to 45 in-lbs (5 N.m).
Whatever the problem...the solution is to replace everything but the frame. What doesn't make sense is how the relay could be wired backwards following this procedure...the tech only has to disconnect an electrical wiring connector...and reconnect the connector. A problem implies that the bad fan is replaced with a bad fan, but the new bad fan can be fixed in the shop?? Scary.
Here's a link to the full bulletin; http://www.alldata.com/tsb/Chrysler/...00_E19/91.html
Old Apr 20, 2010 | 04:16 PM
Mad_Med05X's Avatar
Where is this relay located! My fan don't turn on and they telling my my car had the E19 work done in 2006!
Old Apr 20, 2010 | 07:19 PM
sowardcustoms's Avatar
The E19 is just the fan blade, motor, and fan shroud no relay is replaced not sure what they done it doesnt sound right tho....
Old Apr 20, 2010 | 07:27 PM
The cooling fan module (relay) is right behind the driver headlight..
PNA
Nov 12, 2020 04:44 PM
GraphiteGhost
Jun 15, 2017 12:07 PM
waldig
Sep 2, 2015 11:02 AM
onehundred80
Jul 5, 2015 06:41 PM
Fupa13
Aug 13, 2006 12:37 PM
