Removing SRT Roadster Antenna
Old Sep 22, 2006 | 01:51 PM
Rickyms's Avatar
Default Removing SRT Roadster Antenna
I just puchased a car cover that requires the removal of the radio antenna. Is the antenna easy to remove, I remember trying to hand turn it but it did not budge?
Old Sep 22, 2006 | 02:18 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Removing SRT Roadster Antenna
~ it should just unscrew at the base...
righty tighty ... lefty loosey.
Old Sep 22, 2006 | 05:27 PM
MMZ_TimeLord's Avatar
Use a wrench with masking tape on it... or what they call a 'fitting wrench'. These are designed to grab more than just 4 sides, they tend to grab about half of the 5th and 6th sides so as to really grip the fastener.
You can also get the special wrench for working with A&N fittings, these are softer so they won't mar the finish.
Old Jan 16, 2007 | 10:51 PM
mss400's Avatar
OK. I don't get it. Do you unscrew the antenna from the outside or do you untighten something from within the trunk? I need to cut the hole for my new car cover...
Old Jan 16, 2007 | 11:25 PM
feets's Avatar
unscrew it from the outside.
Old Jan 16, 2007 | 11:48 PM
al_luss's Avatar
I have asked this before, but got no answers. Has anyone ever found a power antenna that would fit in the fender area? This way we would not have to remove it each time.
Old Jan 17, 2007 | 12:03 AM
mss400's Avatar
When you say unscrew from outside, do you mean just firmly grasp the round base and twist?
Old Jan 17, 2007 | 10:05 AM
Rickyms's Avatar
Simple yes.
Old Jan 18, 2007 | 12:32 AM
mss400's Avatar
Oh. That was easy.
66L72M21
Jul 27, 2015 01:28 PM
leaddog2015
Jul 13, 2015 12:25 PM
SuperD500
Jun 23, 2015 02:48 AM
bmaynard06
Jun 22, 2015 09:04 PM
andrew
Apr 13, 2004 07:35 PM
