Need advice to buff headlights on SRT6
Old May 23, 2007 | 12:14 PM
Bostonsrt6's Avatar
Default Need advice to buff headlights on SRT6
Hey guys...I purchased my srt6 about 2 months ago and just noticed there is a chemical on the headlight on the surface...I have been trying different methods to take it off but I have had no luck. I went to my local crossfire dealership to get it fixed and the guy said he would charge me 125 to take the solution off. That seems pretty expensive in my opinion. Do you guys have any suggestions...I will take pics today or tomorrow to show you guys.
Old May 23, 2007 | 12:20 PM
Default Re: Need advice to buff headlights on SRT6
He's full of it. You can try a car polish that's safe for plastics and use your buffer. if that doesn't work. Here's an excellent product that's specifically for polishing plastics. I use it and can tell you I get great results.
http://www.novuspolish.com/polish-home-frameset.htm
Old May 23, 2007 | 12:39 PM
RPM's Avatar
RPM
Moderator
I've used Meguiar's PlastX before. It works pretty well and is only about $6/bottle.
Good Luck.
Old May 23, 2007 | 03:18 PM
Bostonsrt6's Avatar
Thanks for the advice so far...as for the buffer part I do not have one and I am not sure if this is something that can be expensive to invest into...As for the Novus stuff I already tried that as well and did not have any good results. I will try the PlasticX stuff. I will also take some pics of the headlights and you guys can tell me what you think. New headlights are around $320 each...expensive...
Old May 23, 2007 | 03:32 PM
Maxwell's Avatar
do you guys know if there is any kind of coating on the headlamps that may be damaged by polishing?
Old May 23, 2007 | 06:32 PM
Maxwell, thanks for changing your avatar again. It was starting to freak me out. I don't like guns pointing at me.
I don't think it has a coating, but if it does it is not affected by the polishing.
Old Jun 1, 2007 | 01:04 AM
jtphillips's Avatar
I almost bought one from Carmax that had fogging on the headlights. The salesman told me you can buy a 3M product that buffs it out for about $8/bottle. Didn't inquire further and went to the Chrysler dealer across the street and bought a different SRT!
Old Jun 1, 2007 | 02:27 AM
saxman's Avatar
use a toothpaste containing baking soda and a terrycloth or microfiber tower.
Next apply a semi thick layer of the tooth paste to your lights.
Just buff the toothpaste off with some decent pressure and rinse with water. Here is the before and after pics.
Old Jun 1, 2007 | 07:54 AM
andrew's Avatar
-C-I-C-C-I Associate Member
~ impressive results.
Old Jun 1, 2007 | 07:59 AM
RPM's Avatar
RPM
Moderator
Toothpaste huh? Looks good.
Guess I should try the Meguiar's Plastx stuff on my teeth and see what happens - .
Old Jun 6, 2007 | 05:42 PM
Bostonsrt6's Avatar
Hey dude I want to try this can you post pics...the pics you have won't show.
Thanks!
Old Jun 6, 2007 | 06:37 PM
truecarolinablue51's Avatar
My dealer just ordered some headlights for me under warranty. I'm happy about that since it's a different dealer from where I purchased the car. If you punch them hard enough they will replace them.
Old Jun 6, 2007 | 09:39 PM
saxman's Avatar
Thanks!
have you tried copying and pasting the link location? there shouldn't be any reason they're not showing up for you.
Old Jun 6, 2007 | 11:17 PM
Brent's Avatar
When I had my Crossfire in for warranty work a few weeks ago my service manager had asked me what was going on with my lights since he could see the deterioration on one of the lenses. We talked about it briefly and I casually mentioned that some dealerships were replacing the light assemblies under warranty. He said he would see what he could do about it. This was on a Thurs evening after work. The next day the dealership called at noon and said my new replacement lights had come in.
Brent
Old Jun 7, 2007 | 10:19 AM
Bostonsrt6's Avatar
So I talked to one dealership and they would not replace it...I am going to talk to another one and see what they say. The only thing I am worried about it I have xenon bulbs in the car. Do you recommend taking them out before taking to the dealer?
Old Jun 7, 2007 | 10:53 AM
XFiringInNC's Avatar
I'm not sure what yours look like, but I had that fogging on mine when I got it and PlastX fixed it right up. They sparkle like new now.
Old Jul 2, 2007 | 02:40 PM
Display_Name's Avatar
Thanks to everyone for the advice on PlastX.
It worked wonders on my headlights, quickly removing the haze with just light hand rubbing using an old t-shirt.
I tried the toothpaste trick first, but it didn't touch the haze.
Old Jul 2, 2007 | 03:43 PM
62thunderbird's Avatar
When I took delivery of the '05 600 miles ago, the headlights appeared as if someone had sanded them. You could feel the degradation of the surface. Dealer tried to buff them out to no avail. So they ordered 2 new headlights. They said there was a protective coating on them from the factory, and it was coming off (?)
Old Jul 2, 2007 | 06:20 PM
Breezewa's Avatar
Try oxy pads. Don't use on paint.
Old Jan 19, 2008 | 06:24 PM
KrzyFast's Avatar
Just an FYI for the members:
I have a mazda 95' 626, don't laugh it is my bad weather daily driver (35mpg)...anyway the headlights had turned completely yellow. Driving at night was like trying to see using candles. Wasn't good.
The Fix: WetSand the headlights.
Here is what I did.
1. I used masking tape all around the headlight assembly so i wouldn't scuff the paint (any worse than it currently is).
2. Begin wet sanding with 800 grit paper
3. Next use 1000 grit paper
4. Follow up with 1500 grit paper
5. Finally polish with 3M Polishing Compound for Plastic Headlamp assembles using a power buffer.
(Doing this last step by hand will obviously take longer) This step gets those fine scratches out
and makes the headlamps look brand new.
Remember: When wetsanding, keep the surface and paper wet.
I was amazed at the results on the Mazda. Since it is older the plastic on the headlamps is thicker, so I am not sure how it would turn out with on the CrossFire?
However, I did want to post this for anyone with an older car with yellowed headlamps. It is well worth the 1.5hrs to be able to see at night. (This time does include the necessary Beer brakes of course)
And of course it is much cheaper than buying new globe assemblies.
Hope this helps someone out!
Cheers,
KrzyFast
