there goes my ic pump !
Old Jun 19, 2007 | 11:29 AM
vladie22's Avatar
Default there goes my ic pump !
after reading all the stories and crossing my fingers hoping it doesn't happen to me, i think my ic pump is giving up the ghost. i have the sluggish acceleration and you can feel the supercharger kicking on and off on the highway sometimes .at times it wants to go, other times it feels like i have no power, and other times it feels like after a while it will kick itself on. my lease is basically up though so i probably will NOT bring it to the dealer to fix it. is that wrong ? the next buyer can get it fixed.
Old Jun 19, 2007 | 11:32 AM
SRT6_Roadster's Avatar
Default Re: there goes my ic pump !
My opinion is to just take it in and get it fixed. You are still under warranty just get it done.
Old Jun 19, 2007 | 03:12 PM
Sidez's Avatar
yea sounds like the ic pump...
Old Jun 19, 2007 | 03:14 PM
SRT6-Man's Avatar
Are you sure its the int cooler pump? My car has been sluggish at times to, but I thought it was the heat outside. When it happened it was 95+ outside...
I only have 6,000 miles on the car. Let me know if you find out what the problem is...Thanx...
Old Jun 19, 2007 | 03:22 PM
vladie22's Avatar
it has only happened lately since its been really hot, but the symptoms sound like the same that everybody has been experiencing with ic pump failures.
Old Jun 19, 2007 | 11:29 PM
CMDXF's Avatar
I was having the slugo problem and took her in, they had to order part. IC. They put new part in and trust me on this one. If you have a SRT-6, this car should never EVER be sluggish. She's a beast now that she's fixed. Awesome car.
Old Jun 20, 2007 | 11:46 AM
AMGLover's Avatar
Message Deleted
Old Jun 20, 2007 | 11:52 AM
I agree, plus it's the right thing to do. Put yourself in the new owner's shoes.
Old Jun 26, 2007 | 10:53 AM
vladie22's Avatar
well, i tried ! i brought it in to have them fix the IC pump. they did the E19 recall while it was in. they drove the car for over 20 minutes (in 90 degree FL heat) and could not replicate the SC shutdown and sluggish acceleration i was experiencing. they said they hooked the car up and it didn't pull any fault codes either. i must say though, on the way to work today i noticed the car runs cooler (temp wise) than before the recall (fan relay) and i only felt a tiny bit of sluggish acceleration before the SC kicked in.
Old Jun 26, 2007 | 11:49 AM
AMGLover's Avatar
Message Deleted
Old Jun 26, 2007 | 01:55 PM
distantpulse's Avatar
Just out of curiosity, how hot was it running before on the temp gauge? What was the difference in temp when they replaced the E19 module?
Old Jun 26, 2007 | 02:03 PM
vladie22's Avatar
before the recall it always ran right at the mark that was half way up on the temp gauge. occasionally it would go just above that line on hot days or during lots of sitting in traffic. now it runs slightly below that mark.
Old Jun 26, 2007 | 04:03 PM
Interesting...Mine runs slightly above the half way mark pretty much all the time. I guess mine needs replacing too? I also put in water wetter, but it didn't do a thing...
Old Jun 28, 2007 | 07:14 PM
CMDXF's Avatar
Your car should not be sluggish at all. I found that out when they fixed mine. NO codes come up on this fix. What I did was got the MECH. to ride with me. We rode around for about fifteen minutes then I tried to mimic the exact speed I was going when I would decide to kick it. That worked , it did the slugo thing and the MECH recognized the shut down immediately. Next time it happens to you try to look remember the speed and how long you have been driving before it happens. Worked for me. Hope this works for you. Its amazing when this car is fixed. You will think you have a new car.
Old Jul 2, 2007 | 01:07 PM
vladie22's Avatar
New Update: was on the highway last night and noticed something interesting. the sluggish acceleration still comes and goes on the highway. however only when the car is in drive. i manually put the transmission in 4th gear and accelerated - no sluggishness at all, same thing in 3rd gear. it seems this problem is only when the transmission is in "d" at highway speeds . hmmm...
Old Jul 2, 2007 | 01:45 PM
AMGLover's Avatar
Message Deleted
Old Jul 2, 2007 | 01:51 PM
vladie22's Avatar
Originally Posted by AMGLover
O.K. Here is the explanation... The great thing about this car is that it is well balanced freak-Just look at what a little ECU reprogram will do... - when you are on the highway in 5th (overdrive) and you mash the gas the ECU does not think "hey this boy wants to race" but a la Mercedes "ah we need to gain some momentum". Now if you had enough room and patience you would see that if you mash the gas going 65 and HOLD it 120 will be upon you quicker then you think and in a very stealthy fashion. Why? Partly for MPG requirements and the EU-4 emissions standards, but that is why the car has the AMG tuned speed shift program...to learn more search speed shift on the forum. Your car seems to be working correctly...I think you need to spend some time in a regular car, your getting jaded.
sounds good...except that i am mashing the gas and nothing! the car worked fine until about 1,000 miles ago. there is definitely something wrong. trust me, if it happens to you, you will know what im talking about. when you push down on the throttle as hard and as far as you want to, no response.
Old Jul 2, 2007 | 01:57 PM
AMGLover's Avatar
Message Deleted
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
tritongreen
Sep 18, 2015 07:32 AM
81's
Sep 13, 2015 04:34 PM
