AC Problem
Old Jun 19, 2007 | 11:46 PM
SRT-6'er's Avatar
Default AC Problem
Has this happened to anyone - when I turn the AC control to "0" the air is still blowing and the "snowflake" light is till on.
I can't get the AC to turn off... which isn't an immediate problem because it is almost July and I live in Houston!!
Old Jun 20, 2007 | 12:38 AM
04Fire's Avatar
Default Re: AC Problem
Had the same thing... take it in to the dealer and they will replace the A/C control unit under warranty.
Old Jun 20, 2007 | 08:30 AM
bflinn's Avatar
I have a problem similar in that after the AC is turned off (snowflake light goes out) it seems to continue to run for several minutes, eventually turning off - but a long time after the it has been switched off. Does anyone know if this is the same/related problem or different?
Old Jun 20, 2007 | 11:01 AM
snowtop57's Avatar
Is the recirculate button also lit up? One of the features of our A/C system is that you can still have the air/heat run for approximately 10 minutes after the car is shut off when the recirculate button is pushed on.
Old Jul 28, 2007 | 10:31 AM
NeverEnough's Avatar
I'm having the same problem. I just picked that car up, and didn't know any better till I really started playing with everything a few days later. I noticed that with the fan Speed control in the "O" position, that air was still coming out. I can turn the AC on and off with the Snowflake button, but air is always blowing. The other thing that I noticed is that there is no fan speed increase after position 2 1/2. 3,4, and 5 don't respond at all. It isn't a major problem as it's hot as hell here right now, but I guess I'll get it checked out a little later. It just annoying to have to keep adjusting the temperature dial to stay comfortable, because all the way cold will freeze me out even on "O". Even when it's 90+ degrees, I find myself setting the temp dial on the white dot to keep from getting too cold. I guess this will be my first service experience with the Stealership. My dealer is a big one, so hopefully they have worked on a couple XFs before.
Old Jul 28, 2007 | 04:46 PM
SRT-6'er's Avatar
Yep mine was the same deal. The dealer fixed it in an afternoon and no problems since.
franklindm
Mar 14, 2020 12:23 PM
eikon
Sep 9, 2019 10:16 PM
Sterling57
Apr 11, 2016 06:11 PM
Steven 4190
Nov 25, 2015 10:12 AM
jimf
Oct 10, 2015 10:22 AM
