Is the brake install any different on the SRT
Old Jul 23, 2007 | 03:04 PM
bflinn's Avatar
Default Is the brake install any different on the SRT
Hi. I replaced the pads (front & rear) on my 2004 coupe by following the great & detailed instructions posted by Andrew and had no issues or problems. I have since upgraded to an SRT-6 and have new pads on order - and knowing the brakes on the SRT are different (mostly larger and vented rears)...
Is there any difference in installing pads on an SRT vs a non-SRT? If so, what is/are the difference(s) and/or tips?
Thanks in advance - (I searched for a similar question but couldn't locate it, so if previously asked & answered, sorry).
Old Jul 28, 2007 | 01:24 PM
bflinn's Avatar
Default Re: Is the brake install any different on the SRT
Based on my lack of responses from my first post...I just finished replacing/changing the brake pads on my SRT 6 (it has 800 miles on it) and will therefore submit an answer to my own question in case anyone else was curious (probably not).
I had already swapped pads on a 2004 coupe and assumed it would be very similar to replacing pads on my "new" SRT-6...it was with two (2) noted differences; 1) The front caliper slide pins are Torx heads and not allen heads as were on my 2004 coupe (so you'll need a torx socket - size T40); and, 2) the rears have two (2) retaining clips in lieu of one...everything else is just like the step by step instructions posted by Andrew.
Also, I replaced my stock pads with EBC Red Stuff ceramics. First test drive was noise free and I did not notice any difference in performance. Plus the red shoes look distinctive (to me...IMO). Also I am posting (with a pic) in a separate thread that I found a "chunk" missing from my left front outboard pad...as I mentioned only 800 miles on the car...I assume an isolated incident.
Old Jul 28, 2007 | 02:11 PM
maxxm's Avatar
Originally Posted by bflinn
Based on my lack of responses from my first post....I just finished replacing/changing the brake pads on my SRT 6 (it has 800 miles on it) and will therefore submit an answer to my own question in case anyone else was curious (probably not).
Yes, definite curiosity here. Thanks for the info and the insights. And I certainly do hope that the missing "chunk" was nothing but an isolated incident and not a sign of a mechanical flaw across the range.
Old Jul 28, 2007 | 02:19 PM
crossfirefun's Avatar
Thanks for the heads up! I am also looking to swap out to new pads in the future.
Old Jul 29, 2007 | 05:20 AM
BrianBrave's Avatar
<--- Huge Horsepower
I have rotex pads on order - thanks for the great info and enjoy the ride.
BTW - did you consider painting your calipers. I also owned a Limited and the calipers were stock silver and looked great. But my stock SRT calipers are black and always look like there dirty.
Old Jul 29, 2007 | 08:32 AM
bflinn's Avatar
Actually I am debating whether to paint the calipers...I never thought much about it until the Red Stuff shoes jump out...bottom line is yes, I am thinking about it.
Old Jul 29, 2007 | 04:49 PM
eganders's Avatar
I am interested as well. Thanks for the heads up.
I don't know anything about the various choices, but why did you decide to go with EBC pads? For me, the huge issue is brake dust.
Old Jul 30, 2007 | 10:07 AM
bflinn's Avatar
I was looking for the lowest possible brake dust as well, and alot of forum members like the Rotex. I previously had put Akebono ceramics on my 2004 coupe and saw extremely low dust and wanted the performance of ceramic so I went with the EBC Red stuff. I would have went back to Akebono, but they don't make a pad (apparently or that I could find) for the SRT. So far (about 150 miles) there seems to be virtually no dust - so it seems to have accomplished my goal and I think they were a little cheaper than Rotex's ($92 for front and $68 for rear).
Check the following link for more info on the EBC.
http://www.ebcbrakes.com/automotive.html
4drturbo
Jan 3, 2019 02:46 PM
tom2112
Dec 1, 2015 09:02 AM
Rusty475
Jul 13, 2015 10:03 AM
Blackout317
Jul 7, 2015 08:38 PM
bradleykologek
Jul 6, 2015 02:49 PM
