SRT6 VS SRT6 W/ Renntech kit
Originally Posted by Steve Hellums
I was thinking that Renntech told me between 20 to 21 @ max RPM and crank HP at the very least of 385 and could go up to 395 depending on the car and octane of the fuel.
and I know that the Let Pulley is larger than the renntech or asp and if this renntech was 20-21 Let Pulley would be around 23 and that would probably not work...
Originally Posted by Sidez
those numbers are too high the supercharger clutch is proven to slip at around 23 psi...
Originally Posted by AMGrasoul
I'm interested to know where this was proven... I've heard it before but do not know the original source. I'm making a pulley that's larger than the LET pulley, but I wouldn't know how to quantifiably determine if it's actually slipping. Do you have a link somewhere?
What size are you looking to make the pulley?
Vadim from Mbworld.org proved it a while back.. the thread is there, but it is a real pain in the *** to find it there...
192mm, already made and fitted. Made a 97mm water pump, but I need to get it shaved just a bit more. It fits, but it's a close call, and since the WP pulley is steel, a thin wall should be fine. My only obstacle is finding a belt that fits. I believe stock is 113.5" and I have a 116.25" belt on order, and I'm hoping that fits. Belts that large and with that many ribs are hard to come by. Even the one I did manage to find was only 7 rib.
Please post a few pics if you get the chance.
Make sure you log your IAT's and timing and get your car dyno'd. I am interested in seeing the results of your large pulley. Hopefully you will have great results.
Originally Posted by Chi-Town SRT/6
With a 60 foot time of 1.8-1.9 you'll knock a few tenths off that time. Your trap speed is definitely capable of lower 12's.
Originally Posted by Sid3ways
I know how you feel.
freakingfastsrt6
49
Sep 30, 2018 02:03 AM
JesseJamessrt6
Feb 9, 2012 01:08 AM
Steve Hellums
26
Jan 22, 2007 04:29 PM
