question - Sprint booster installation
Old Oct 10, 2007 | 04:25 AM
simon-srt6's Avatar
Default question - Sprint booster installation
Do I need to disconnect the battery ?
If I do disconnect the battery will it effect the emissions / require a code for the radio ?
Should I do a Throttle reset before I fit it ?
Can I still do throttle reset with it fitted / will I need to at any time ?
Old Oct 10, 2007 | 04:51 AM
danimal's Avatar
Default Re: question - Sprint booster installation
You do not need to disconnect the battery.
If you do disconnect the battery, no codes are required and it will not effect emissions.
You can do the throttle reset whenever you deem necessary. The sprint booster does not prevent you from doing it.
Just install it...and drive it like you stole it!!!
Old Oct 10, 2007 | 06:24 AM
simon-srt6's Avatar
Thanks for the help. Out with the torch tonight for a late installation then.
waldig
Jul 31, 2017 09:46 AM
waldig
Sep 2, 2015 11:02 AM
josh armstrong
Aug 18, 2015 12:36 PM
Aug 11, 2015 05:19 PM
