DEI's Chill Charger IC fluid
Old Feb 14, 2008 | 11:05 PM
NeedsWings's Avatar
Default DEI's Chill Charger IC fluid
http://www.designengineering.com/pro...sp?m=sp&pid=62
ill pick up a bottle from our distributor tomorrow and see how it does, well ill add in a coolant temp gauge to the system first and get some before numbers first but this may be a very nice cheap mod for us
Old Feb 15, 2008 | 07:51 AM
NeverEnough's Avatar
Default Re: DEI's Chill Charger IC fluid
I put 2 bottles of Redline Water Wetter in mine and it made a difference according to the guage. It used to sit slightly above the 1/2 mark, not it sits below it. I'd guess about a 10 degree drop...
Old Feb 15, 2008 | 08:02 AM
RPM's Avatar
RPM
Moderator
Where did you pick this stuff up?
Is this similar to water-wetter?
TIA.
Old Feb 15, 2008 | 08:14 AM
BlUEMDsrt6's Avatar
Sounds good, thanks for keeping us posted NW.
Old Feb 15, 2008 | 08:25 AM
distantpulse's Avatar
Funny, I put the same thing in mine during the summer. I didn't see much of a difference......The only time it made a difference, was when i was crusing. It did seem like it took longer to reach the half way mark when I first started driving. Other than that, if I was sitting in traffic, the guage would still read above the half way mark. Then it would pretty much stay there unless i was crusing.....
Old Feb 15, 2008 | 08:53 PM
Well yeah. Mine does the same thinng. With no air flow it's still going to get hot. It does help eliminate heat soak when you are moving. I plan on doing a fan mod or add a couple of small fans to take better advantage of it.
Old Feb 16, 2008 | 07:36 AM
Moparrbust's Avatar
Has anybody considered swapping the stock thermostat for a cooler one? I did that on my Charger and it is consistantly 20-30* cooler than stock.
Old Feb 16, 2008 | 08:09 AM
Maxwell's Avatar
I've tried water wetter and see no difference, as for IC coolant the best liquid is water with no antifreeze. De-ionized of course.
Old Feb 16, 2008 | 09:37 AM
MikeR's Avatar
TVT says that theirs drops the temps from 220* to 180*-185*. I was thinking about getting one. Does anyone have this on their SRT?
MikeR
Old Feb 16, 2008 | 09:42 AM
Maxwell's Avatar
MikeR
I've read about the thermostat mod on the MBZ forum, it's a DIY project, I think the stock thermostat might be restrictive and some guys ported the OEM one for higher coolant flow. not sure how to change the opening temp.
Old Feb 16, 2008 | 09:53 AM
MikeR's Avatar
Their ad says "We've left the stock opening temperature as to not interfere with the fan or heat." It looks like it's just a swap out and top off the coolant.
MikeR
Old Feb 16, 2008 | 10:18 AM
parawxman's Avatar
Like waterwetter...you need to swap out your entire volume of coolanat to make any real difference. One bottle doesn't make any noticable change in temp biggest change is in your wallet. Topped off with two bottles...net change was 17 dollars
syfi
Mar 28, 2026 04:14 PM
UNDER PSI
Nov 1, 2015 09:39 PM
jimf
Oct 10, 2015 10:22 AM
Jackobo
Sep 24, 2015 10:21 PM
Valk
Sep 17, 2015 11:43 AM
