Tire/wheel help
Old May 16, 2008 | 07:39 PM
MD SRT6's Avatar
Default Tire/wheel help
I would like to go down to a 15,16,17" rim on the rear and add the biggest racing slick that I can to alter my gear ratio to the lowest I can get it and still have a pretty big sidewall ( 3:50- 3:70 or so ratio?) strictly for drag racing, any info appreciated! I have seen wheels w/ 5 x 112mm x 17 with 36 offset but nothing smaller. And how big of a tire/wheel combo do you think will fit? I know there are alot of number crunchers out there, please help! Thanks in advance
Old May 16, 2008 | 08:12 PM
Default Re: Tire/wheel help
I can't answer your question right now but am working on the same thing
Old May 16, 2008 | 10:27 PM
SRTpowa's Avatar
What about brake clearance? I would love to do the same thing, but my 17's barely clear now?
Old May 17, 2008 | 09:09 AM
240M3SRT's Avatar
I too am working on figuring out the same thing. I will NOT go back to the track without a set of real slicks in the trunk. I did some test fitting and i "think" a pair will fit in our trunk.
Cruizenquick is running 16's but i wonder if any 15's will clear the brakes? The smallest wheel w/ the most sidewall should work best.
Old May 17, 2008 | 09:14 AM
Moparrbust's Avatar
I have a set of 220 body S-class wheels that are 16x7 1/2 that bolt rite up and BARELY clear the brake caliper..........but I decided against using them due to the skinny width.
Old May 17, 2008 | 09:43 AM
SRTpowa's Avatar
Hey check out this wheel I found on EBAY UK.
It's a mercedes spacesaver wheel. These might work for some skinnies up front, but I have no idea what car they come off of or where to get them?
http://cgi.ebay.co.uk/Mercedes-Benz-...ayphotohosting
Old May 17, 2008 | 09:47 AM
Moparrbust's Avatar
I've checked that idea out as well.........the BIG problem is that you can't get any tires that'll fit on the 17'' M-B spares AND fit our OD needs. You can NOT run down the drag strip on spare tires as they are rated to 55mph and you will get kicked off the track(if the tires don't fail at 110+mph and you get wiped off the track).
Old May 17, 2008 | 10:06 AM
SRTpowa's Avatar
I was thinking slap some Mickey Thompson ET fronts on there or another brand of skinnies, but I'm not sure how the ECU would react to the lower overall OD. Then again if you can get some low overall OD 15's in the rear it might balance things out? The computer only cares about the difference in speed between the two correct? Hossier makes a 275/35/15 that would be perfect if you could find a 15x9 wheel that would clear in the rear.
Old May 17, 2008 | 10:50 AM
NeedsWings's Avatar
we are running old school 16" rims with mt et streets, we just sold the other 2 from the set we got our 2 from but ill look and see if there are any more that size in the store room at the benz shop, 16x8.5
Old May 17, 2008 | 02:27 PM
MD SRT6's Avatar
Thanks, let me know. What is your tire size on that rim?
Old May 17, 2008 | 02:32 PM
MD SRT6's Avatar
That would look pretty wicked up front, I'm not sure how stable it would feel though.
Old May 17, 2008 | 04:07 PM
cruzinquick's Avatar
You can see mine in my gallery. I have 15mm spacers and have no problem with any rubbing and still able to use the stock lugs. Mine are as close to stock height as you can get. 26.4". The rims are mercedes 16x7.5 the minimum width for the tire.
Old May 17, 2008 | 04:22 PM
NeedsWings's Avatar
mt et street's (wrinkle wall, basically et drags with some slits cut in them to be dot legal)
26x10.5x16
(we get discounts on them if you need a set)
Old May 17, 2008 | 04:32 PM
Rob what pressure you running at the track? I may give these a try on my next set. I'll probably need some in a month or two.
Old May 17, 2008 | 05:16 PM
MD SRT6's Avatar
26x10.5x16
Do you think a 27 would fit up in the well? That is exactly the style of tire I'm after. My hoosier's ain't cutting it, not enough sidewall. Plus I'd like to alter the ratio some, by going taller.
Old May 17, 2008 | 06:55 PM
NeedsWings's Avatar
we start at 20, if it doesnt grip i drop to 18, if still doesnt grip i drop to 16.
i want as much psi in there as can grip with, as the rolling resistant is worse the more air we let out.
Old May 17, 2008 | 06:58 PM
NeedsWings's Avatar
i havent tried them sorry, the pic i attatched a few post up shows a launch and its sqautting pretty good there with the 26's. i thought you wanted a smaller rear end diff, smaller tires would do that for you aswell, why the change of direction with going bigger now? focusing on the nitrous passes instead of the non nitrous i assume.
Old May 17, 2008 | 07:45 PM
MD SRT6's Avatar
Actually my dislexia kicked in and I had it backwards 26x16x10.5 would be perfect, as soon as I find some rims, I'll order some tires from you. Thanks
Old May 17, 2008 | 08:14 PM
RIOT's Avatar
I tried Merc. 15" rims and they wouldn't work.
Old May 17, 2008 | 09:07 PM
tom2112's Avatar
She can ride with me ;)
Just curious, since I'm now afflicted with the drag racing addiction...
How much money do you have in those tires and wheels, Rob?
Also, I would LOVE to know if a pair of those would fit in the trunk. I'm betting you could only get one in there.
