hey guys (inner cooler ?)
Old May 23, 2008 | 04:15 PM
Samstin's Avatar
Default hey guys (inner cooler ?)
I am having mine replaced tuesday , just want to make sure you guys think this is whats causing my problem.I have terrible hesitation going up hill and on turns and occassionally when i get on it around 35-45 mph.
also having my needswings air intake installed after the dealer covers the cooler through warranty!
thanx as always!
steve
Old May 23, 2008 | 04:23 PM
robby363's Avatar
Default Re: hey guys (inner cooler ?)
Do you mean the intercooler pump? That more than likely what it is the oem pump fails on just about all of the srt6 sooner or later.
Old May 23, 2008 | 04:50 PM
Jeff Cobb's Avatar
Yep - the intercooler pump is so notorious for going out that some have replaced them before failure.
Part # 10-24504-03 - the one I saw was $120, but I didn't shop around; I'll wait for mine to fail.
If you're really lucky you can get a discount from Rob at NeedsWings w/the CAI, and convince the dealer to install a better pump since the OEM Bosche pump is a POS.
The only other issue that I've seen pop up more often are fogged headlights & the little lens on the fog lights (earlier production SRT's) popping off.
Old May 23, 2008 | 05:21 PM
Samstin's Avatar
thanx guy,
i guess the intercooler pump, the dealer has the parts.
and yes JC the headlight lens are fogged!
cant wait to have my intake installed!!
thanx again guys
steve
Old May 23, 2008 | 05:33 PM
Jeff Cobb's Avatar
Sure thing.
You'll like the CAI, and Rob is a great guy to deal with.
Eventually I also want to add a sprint booster, 178mm pulley and ECU tune.
Not the fastest mod package, but all with a good track record, and I won't have to upgrade the HE or thermostat.
BTW - where are you?
Old May 23, 2008 | 07:32 PM
Samstin's Avatar
Buffalo NY with the possiblilty of tega cay sc, ill know in the next 2 weeks...
steve
Old May 23, 2008 | 07:41 PM
Jeff Cobb's Avatar
If you move, you've got to go to the Tail of the Dragon meet in the fall.
About 4 hrs away.
Over 70 XF's in the spring, but the fall run is better because these cars run much better at lower temps.
Old May 24, 2008 | 09:12 AM
Samstin's Avatar
Sounds Good!
gblack32
Sep 7, 2016 08:27 PM
yorxs
Aug 18, 2015 07:21 PM
Tp'sfury
Aug 13, 2015 08:20 PM
3spencer3
Jul 24, 2015 01:08 PM
bradleykologek
Jul 6, 2015 02:49 PM
