just curoius about this
Old Jun 20, 2008 | 12:53 AM
XfireX's Avatar
Default just curoius about this
my temperature meter is 90% of the time a millimeter or two slightly above the middle, i thought it was always a little below the middle
im asking this becuz of radiator problems in the past
Old Jun 20, 2008 | 05:09 AM
Voyager's Avatar
Default Re: just curoius about this
it depends on the day for me. im not speaking for anyone else but i know on hot days mine is at middle or over. until it sits for a bit
Old Jun 20, 2008 | 05:12 AM
Stogey's Avatar
It's running normal !
Old Jun 20, 2008 | 05:15 AM
stevieb's Avatar
+1
Mine is the same
Old Jun 20, 2008 | 06:06 AM
Montana Crossfire's Avatar
Same here but I do have a 185mm crank pulley.
Do you have inceased boost?
Old Jun 20, 2008 | 06:35 AM
BLKFIN's Avatar
ADDICTED TO BOOST
The same here....right at or slightly above with stock pulley. With my Code 3, it is now always slightly above the middle line.
It is fine!
Old Jun 20, 2008 | 07:49 AM
MMZ_TimeLord's Avatar
Yep, I have to chime in... just a needle width above the center line is normal operating temp.
Cheers!
Old Jun 20, 2008 | 12:44 PM
waldig's Avatar
Talking Re: just curoius about this
Check this out, this is my gauge with the new thermostat that I have been developing and testing. It's a 172 degrees STANT stat that will work in the crossfire with work. Now that the PO221 code problem is fixed I can get back to my write-up of the mod and its operation, Enjoy Woody
P.S. I also have a "LESS THAN 10$ FIX TO GET THE FAN TO RUN MORE (FASTER - ADJUSTABLE)" to go along with the stat, sorta like a package.
Ill get to this next week as I have sat and sun autocrosses this weekend, Bee good. W
Old Jun 20, 2008 | 01:41 PM
Coyote's Avatar
Woody, be sure to properly inflate your tires before you autocross events.
Coyote
Old Jun 20, 2008 | 02:11 PM
Voyager's Avatar
and how long was the car running for that picture. that is a huge drop in temp if it was running for while
Old Jun 20, 2008 | 04:13 PM
waldig's Avatar
Well Guys that is where the car runs on the street after I made my mods. About 172 F degrees, or a segment lower than the stock middle position: However the motor believes it is at the Mid position. Love beating up on a computer and still winning.
The tire light is my nemesis. I can not get rid of it, tried magnet and Full Air pressure and nothing. I dont know YET how to get the sensor to go to sleep. I DONT WANT IT AND I BELEIVE IT AFFECTS THE BAS/ESP sensors also. I could use a magic bullet for this problem, makes the throttle body look easy by comparison.....................Woody Enjoy.
Old Jun 20, 2008 | 04:34 PM
Voyager's Avatar
im sorry you lost me. so the temp is always that low. BUT the computer doesnt think its that low? it thinks its hotter than that? and if thats the case wouldnt the car start to pull timing if it raised temps
Old Jun 20, 2008 | 08:40 PM
Playdrv4me's Avatar
It's a Mercedes thing... Slightly above middle is normal from every Mercedes with this kind of temp gauge I've seen.
Lexuses and Hondas on the other hand tend to mock everyone else by running a tick *below* middle, and my BMWs always jump right to TDC.
Old Jun 21, 2008 | 02:29 AM
waldig's Avatar
Its the air temp that causes the timing to be pulled as I understand it. My motor thinks the water is at normal temp but the water is only at the 172 range. The fan is running at a higher rate and the air inlet is cooler due to lower motor temps PLUS the H/E is getting MORE air due to the fan. Ill be on the track in 2 hours and well see how it all works in the real world, not bench racing theories. Enjoy, Woody
technojunky
Dec 11, 2009 07:16 PM
