How Well's The Code 3 Pulley Work?
I like their service and quick response to questions...put 650 miles on the pulley with no issues...weren't cruising miles either...so like what was said already, like the car itself, best bang for the buck for HP>...
I bought mine used from Bikecop and I have about 1200 miles on it and I think he said he put 2000 miles on it. No issues at all and it hauls the mail! No slip, no abnormal belt wear, no drivability changes until you lay into it, then hold the heck on. First thing in the morning, when I haven't had coffee and still groggy, with the engine still cold, I pull out of my neighborhood and hit it hard and it literally gives me virtigo/tunnel vision.
Oh, the one I have is also a Version 1 with notched grooves in the pulley like the stock pulley, I understand that the grooves on the newer ones are not notched out
Originally Posted by NeverEnough
Oh, the one I have is also a Version one with notched grooves in the pulleylike the stock pulley, I understand that the grooves on the newer ones are not notched out
By the Numbers
Ratio or percentage gain in boost over stock @ Prices (from Code3, ASP and LET website) - sales may be on going - call to find out.
13.32% @ $650 = $48.80 per % gained = Code3
14.84% @ $970 = $65.36 per % gained = ASP 178mm
16.77% @ $850 = $50.69 per % gained = LET 181mm
19.35% @ $950 = $49.10 per % gained = LET 185mm
There you have it -- the Code3 pulley is lowest total cost and the lowest cost per % gain (barely) but is also the lowest in performance gain.
The 185MM pulley is $300 more but provides an extra 6% gain in boost.
By the Numbers
I see where you're coming from. That's a good way to look at it too. The only problem with this theory is that all these pulley were tested on different cars in different locations on different types of dynos that were are set up different. These number could easily change all over the place if they were all tested at the same time on the same dyno with the same conditions. .......
I should add that that's percentage of boost drive - not actual PSI - PSI gains are much more.. (around 15%)
Received my Code 3 pulley Friday and installed it right away. When for a drive and by the time I was done (less than 8 miles or so) I hit the dreaded intercooler overtemp. Removed the Code 3 returned to stock pulley after cool down and all is nornal.
Looks like I'm going to need a IC upgrade before I can use the pulley and drive as hard as I do.
Thoughts?
Thoughts?
Negative - These are the hard core ratios determined by pulley sizes and mathematics. Not by different cars, dynos, locations, etc...
Thoughts?
Thoughts?
Hmmm, that's interesting. Sounds like you have a borderline pump. I've had no such issues...
...Oh, the one I have is also a Version 1 with notched grooves in the pulley like the stock pulley, I understand that the grooves on the newer ones are not notched out
What do you guys do with the strap wrenches ?
This was just my car, don't et is scare you away. Everything I touch goes wrong, it wasn't anyones' fault aside from that ******* Murphy and his BS Laws.
Ok just did a quick look around for the Johnson. Where does a guy buy one? LET page isn't working, none on ebay, Google no help.
HELP!!!
HELP!!!
HELP!!!
HELP!!!
http://www.autoperformanceengineerin...ld_jabsco.html
How'd you do that!? Also found the Ford Lighting pump M-8501-L54 on ebay for only $99.90.
Read where that's a good replacement also. Skip that it's an OEM type replacement.
Time to get a Johnson.
Thanks.
Thanks.
By the Numbers
Went head to head with all but the 181 size at the last LET track event. All on SRT6's with similar other mods. All of these cars were with in one tenth of each other all day long. So they are all good pullies, Code3 is just cheaper and way easier to install (most of the time lol )
