Jerry Tune from LET
We modify all maps within the ECU. This includes injection maps during acceleration, injection maps at part load, timing maps at part load, and timing maps during acceleration. We also modify full throttle maps as well.
We up the RPM limiter.
We up the speed limiter.
Octane plays a huge factor in tuning. Cars that run only 93 octane will be able to run a bit more timing on the top end. Cars with 91 octane will need to be a bit more conservative.
Current A/F ratio information and updated dyno charts help us determine what we can do with the tune.
Data logs are huge too. If we know that your IAT's, Engine temp, short term and long term fuel trims, etc are all good, then we can push the tune a bit more.
If you can log multiple sensors, then I would like to see:
Vehicle Speed
Vehicle RPM
Engine Load
Engine Temp
Intake Temp
Intake Manifold Pressure
Short Term Fuel Trims
Long Term Fuel Trims
Timing
O2 Voltage
All of this info would be considered helpful if available.
If you guys care, there are great books on tuning at the book store. It will really open your eyes to tuning.
I can honestly say that tuning is the most important mod you can do.
Vehicle Speed
Vehicle RPM
Engine Load
Engine Temp
Intake Temp
Timing
O2 Voltage
Originally Posted by tom2112
Jerry, thanks for the great response above. I hope InMotion sees this thread and chimes in too.
Can you tell us some of the things that you modify - or should I say account for? (kind of a check list of benefits)
Such as:
Altitude
Octane of Gas available
Redline (RPM limit)
Top speed limit
Throttle map
Fuel map
Modifications (CAI, pulley, etc)
The reason I ask, is I want to know what I information I can tell you (or any other tuner for that matter) that will allow you to tune my car better.
I've seen mention of data logs. Should I send you a data log along with my ECU? Would it help? I have an OBDII connector and laptop with logging software. What readings would you want logged?
Thanks again for your participation in this forum. We appreciate all the info.
Such as:
Altitude
Redline (RPM limit)
Top speed limit
Throttle map
Fuel map
Thanks for the explaination Jerry. I have a question......I am soon planning on running the stage 2 AIS water/meth system. I would assume you would need to retune my ECU. Correct? And if so, what additional gains come from that tune+meth if any?
Yes, and if you could meet up with Anthony and get that car on a dyno, that would be best. It would most likely take a good part of the day to get the system dialed in and the car custom dyno tuned.
A custom dyno tune will always yield more power than a mail tune because we can make onsite adjustments to the ECU.
I have never tuned a 3.2L motor with meth.....should be fun!
Distant was has your time dropped since you got your tune from LET. Your were in the 12.20's without it right? Did you have another tune prior?
thanks,
Cruzinquick
AMGJerry,
So is the group price $499, like on the mb forum?
thanks,
Cruzinquick
AMGJerry,
thanks,
Cruzinquick
AMGJerry,
thanks,
Cruzinquick
AMGJerry,
That's still pretty good to run your best in both temps. What do you expect to knock off when the weather is better? Maybe a tenth? I'll be estatic if I run your current times in my best weather this winter.
Maybe we should have a dyno day in various cities across the country.
That would be a heck of deal - I paid more for my dyno tune - but it was worth it!
Originally Posted by 240M3SRT
The tune is based on what has worked for similarly modded cars.
You should double check a/f via a gauge to make sure its safe. To not have one and simply trust the out-of-box tune is gambling with your engine.
Tuning on a dyno would allow for the tune to be the more accurate than out-of-the-box. In my case i take the car out for a run after i receive the tuned ECU to monitor my a/f gauges and check that its safe.
How Do you check a/f via a gauge during driving? Is it complicated to install a a/f gauge?
Thanks.
Thanks.
Thanks.
Installing an a/f gauge is easy. Have an o2 bung welded into your exhaust for the sensor, preferably before the cat. You route the wires into the cabin and get power from the fuse box. On our cars there happens to be a convienient pre-existing hole by the brake master cylinder, and the fuse box is on the driver side of the dash.
After my pulley and intake were installed my car ran very lean up top. The tune fixed that until i did my intake manifold mod, then it ran lean again. The only way i could possibly know this is from the a/f gauge. Its amazing to me more people here dont run them.
In fact my main reason for the tune was to actually richen my a/f so my car is always safe, not the added power...but thats nice too. Leaner is meaner but only until the ring lands crack.
You simply watch the gauge as you drive. Actually its safer to keep your eyes on the road and have a friend watch the gauge as you do a run or two.
Thanks.
I ran my best time without the tune, but the weather was a hell of a lot better when I ran my best. Now, im close to my best(anywhere from 12.25-12.35), with about 1-1.5 more MPH on the top end and the weather is much worse now so......60fts are about the same. I think I may have been a little too lean without the tune. When I dynoed it after the tune, I was running around 11.5 A/F with nice curves on the chart. So at least i know its in the "safe" zone.
Can you also get accurate data from the OBD-Port or is it impossible because of the OEM-O2-Sensors? I am interested in the data at WOT.
Thanks.
Thanks.
Maybe Jerry or someone else can chime in here on if A/F ratio is data that can be pulled from the OBD port...?
Keep in mind even if it can you really want to know a/f in real time so you can let off the throttle if you run lean.
Im using a Carchip data logger in the OBD port but it only reads IAT, MAP, timing, braking, and speed.
There is a way to calculate narrow band O2 voltage to A/F ratio.
Much easier to just purchase a wide band.
