Line Lock
Old Aug 12, 2008 | 12:21 PM
BlUEMDsrt6's Avatar
Default Line Lock
A worthy mod or not? Pros and cons please.
Old Aug 12, 2008 | 12:42 PM
ZAHANMA's Avatar
Default Re: Line Lock
I think that line lock couldn't hurt depending on how much you do in fact race. If racing is not something you do on a regular basis then I would have to say the time/money you or someone you hire would put into it wouldn't make it worth installing. I do however feel that it is a pretty little ingenius invention. It seems simple enough to install, but how good is the reliability...I'd say go for it, assuming you could put the button in your console and keep it lookin somewhat stock/normal. Go for it. and I'd definately like to know how it helped/hurt you 1/4 mile times. I realize there is no added HP from this, but theoretically it should help you improve your reaction time...woohoo!!!
Old Aug 14, 2008 | 09:36 AM
sonoronos's Avatar
What is a line lock?
Old Aug 14, 2008 | 10:20 AM
Voyager's Avatar
does a linelock still use the brakes?
Old Aug 14, 2008 | 10:23 AM
waldig's Avatar
Talking Re: Line Lock
I would be concerned that the line lock would potentially interrupt the abs operation. The typical line locks were on the front brake line but with ABS there are two separate lines going front, one per side.
Other than that it would be ok. Possibly they have dual circuits for todays car, I have not seen them yet.
Woody, Enjoy the day..............
Old Aug 14, 2008 | 10:49 AM
BlUEMDsrt6's Avatar
I'm no expert but, a line lock is used to lock the front brakes so you can warm your rear tires (burnout without wearing out your rear brakes) and keep the car from moving forward at the line while reving the engine for the launch. Its from what I've seen push button activation.
Old Aug 14, 2008 | 09:30 PM
Voyager's Avatar
yeah but my question is does it use the front brakes or does it do something else? idk what it would do instead but doesnt that put alot of strain on your front brakes over time
Old Aug 15, 2008 | 02:13 AM
MoparJunky's Avatar
a line lock does use the front brakes. it works like this you push your brake pedal down hard and hold it, push the button for the line lock, release your brake and your front brakes stay at the same presure as when the pedle was depressed but the back wheels are free to roll. when you let go of the button the front brakes release.
not sure if our cars have a dual diagonal braking system or not if they do then you have to use 2 line locks.
the only reason to have one imo is to stage your car at the drag strip of corse it makes doing smoke shows easyer.
Hope this helps
Old Aug 15, 2008 | 02:03 PM
Voyager's Avatar
[QUOTE=
Hope this helps[/QUOTE]
yeah but say goodbye to the tires haha
syfi
Mar 28, 2026 04:14 PM
Mackel
Oct 16, 2015 09:03 AM
JEFASOLD
Sep 28, 2015 12:10 PM
Selbyl
Sep 26, 2015 04:15 AM
xjken
Sep 13, 2015 10:18 PM
