SRT6 Dyno
Old Aug 22, 2008 | 12:28 PM
amg-jerry's Avatar
Default Re: SRT6 Dyno
Scott - You are running a little rich on the bottom end. You can add .5 to the A/F when the tail pipe sniffer (O2 Sensor) is used.
5.50 and up looks good.
I like that the trq curve is flat.
Want to send it back in for a few minor adjustments?
Old Aug 22, 2008 | 02:44 PM
BLKFIN's Avatar
ADDICTED TO BOOST
I am going to put it on the dyno again and send you the file. I may take you up on the re tune if you see some more HP "laying on the table"!!!
Old Aug 22, 2008 | 08:27 PM
ProjectMayhem's Avatar
12.5 at wot is high 11.8-12.1 is usally a good sweet spot for boosted vehicals.
Old Aug 25, 2008 | 04:42 AM
Steve Hellums's Avatar
Originally Posted by MikeR
I just had my Aero dyno'd a week ago on a Mustang and it was 308 whp max and 315 wtq max. It was also 96 degrees out so the readings were a little low. I will have to take it back for a cool morning dyno. I have the SL55 intake, 181 and LET tune. On the DynoJet I would think you would be better than 328whp also. My charts were nice even lines all the way through.
MikeR
I agree, Mustang Dyno's are not the way to go if you want to see high #'s. I was sooo disapointed in what my car put down that I thought there was something wrong with their machine. Here is my chart, I could not believe it was that low. Hell, it will break loose a set of 285/35/19 PS2's @ 55 mph.
Old Aug 25, 2008 | 06:55 AM
BLKFIN's Avatar
ADDICTED TO BOOST
I was able to put the Crossfire on a different dyno on Saturday to attempt to help 240M3SRT trouble shoot the odd spike in HP and A/F we saw the last time we dyno’ed the cars. I am finding that the read outs can change fairly dramatically with the different settings of the dyno operator. I see from my first time out that the dyno operator ran the Dyno in MPH apposed to RPM, I also see that he had it set at STD opposed to SAE. I found a difference in the “smoothing” factor as well from 3 to 0. The first operator ran the car up to 150mph on the dyno where the second operator just punched it in 3rd and basically had it up to 120.
The 2nd dyno run was a little hotter outside, 96 compared to 89 so I netted a different result. I have attached 2 graphs to look at. The first is the 3 runs from 8/23/08 and the second is a graph of the best fun from 8/15/08 with the best run from 8/25/08 in the same format that the first dyno operator mapped out. As you can see, there is a 7hp difference in just the format and another 7hp difference between the 2 runs. I guess that is what 7 degrees will do??
Let be the first to say that I have no idea what all this means, other than the A/F spike I believe is a factor of the first dyno operator and is not related to the cars.
File Type: bmp
File Type: bmp
Old Aug 25, 2008 | 02:33 PM
240M3SRT's Avatar
Scott are you sure G2 didnt dyno in 3rd gear because based on the graphs thats how it looks?
Old Aug 25, 2008 | 02:43 PM
BLKFIN's Avatar
ADDICTED TO BOOST
You are right...my bad! It was 3rd
Old Aug 27, 2008 | 12:18 AM
Mimi05SRT6's Avatar
My first time at a dyno was the same as yours, meaning about them not knowing what to do. All they could muster was hp without torque and a/f readings! I'm going out to another shop on Sep. 14th and I'll give them the info that I've learned on here on how to dyno.
Old Aug 27, 2008 | 03:37 PM
NeverEnough's Avatar
Those some very respectable numbers, but it would appear that whoever was running the dyno didn't know too much...
If you want the most accurate numbers, it needs to be CF: Smoothing 5 and be measured in SAE.
Old Aug 27, 2008 | 04:39 PM
240M3SRT's Avatar
What do you mean by CF:Smoothing 5?
Apr 28, 2016 02:04 AM
johnnycross413
Mar 4, 2016 04:49 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
rogerlemoine
Oct 26, 2015 12:02 AM
Sep 28, 2015 07:40 PM
