Noticeable 'shake' At Idle Or Stop
Old Aug 23, 2008 | 04:28 PM
j-fire's Avatar
Default Noticeable 'shake' At Idle Or Stop
Is This Common In Srt-6's? Doesn't Seem To Be Hesitation, But There's A 'short Vibration' Or Shake At Idle.... Anyone?
God I Love This Forum....
Old Aug 23, 2008 | 04:41 PM
No1Piranha's Avatar
Default Re: Noticeable 'shake' At Idle Or Stop
Mine is smooth as a mechanical watch at idle. There's so many things it could be, but try this - fill the tank with a different (and name brand) 93/94 Octane gas and then do an ECU re-set. Just disconnect the battery for 10 minutes.
Old Aug 23, 2008 | 05:09 PM
240M3SRT's Avatar
Mine does this too. Its like i have a mild cam or something. Its enough to wake me up when im trying to sleep(yes i sleep in my car dont ask).
Old Aug 23, 2008 | 05:15 PM
bigbengt67's Avatar
Mine has a slight vibration while idling. I like it, reminds me I'm driving something with a personality!
Old Aug 23, 2008 | 11:34 PM
SRTpowa's Avatar
mine too, I thought it might be missfireing? I noticed my passenger side valve cover is leaking some oil today. They already replaced the driver side. Time to take it in again I'll see if they can diagnose the rough idle as well.
Old Aug 24, 2008 | 04:40 AM
waldig's Avatar
Sounds like a misfire. You can localize it if you wish by pulling the 2 plug wires on each cyclinder in turn. If it begins to shake more, thats not the bad one. When you get it, there will be a minimal difference in the shaking.
You have to do the plug check with the engine off then start it, pulling plugs on a running engine will light you up for sure.
Woody
Old Aug 24, 2008 | 06:36 AM
I have 20000 miles on mine and it has a Shake At Idle whether in gear or not and only when dead still,, I too didn't know if this is normal or not but was palning to do a tune up anyway ,,I'll try the different fuel if that doesn't work then ,,,new plugs it will be. in case some one finds out just what it is just let us know. thank for your help in advance jim
Old Aug 24, 2008 | 12:08 PM
svo's Avatar
svo
I'm almost at 11,000 miles and mine does that too
Old Aug 24, 2008 | 12:42 PM
DerEifelFahrer's Avatar
I've got 65xx on mine and it's rock steady at idle. I use Sunoco 93 octane most of the time. I can't get over how well this car performs.
Auf Wieder
Old Aug 24, 2008 | 12:49 PM
SRT6-Man's Avatar
No shaking here! 9,000 miles on her. I also use 93 octane. Maybe a tune up and better gas, will help you out.
Old Aug 24, 2008 | 01:23 PM
svo's Avatar
svo
looks like maybe it's a 92 octane thing??
Old Aug 24, 2008 | 01:41 PM
NeverEnough's Avatar
31,000 miles Shell 93 Octane only and it has done it since day one of ownership. I figure it's nothing to worry about.
I get great mileage,
It runs great,
No problems,
I just figured it was a characteristic of the car.
Old Aug 24, 2008 | 03:58 PM
240M3SRT's Avatar
I use 93 Chevron. I will mention ive had my coilpacks, spark plugs and wires on and off more than you can imagine. Dont know if thats the culprit.
Old Aug 24, 2008 | 04:04 PM
93 oct BP while i have owned it,, & some times I mix with 2 to 1 ,,105 unleaded race gas
Old Aug 24, 2008 | 05:30 PM
musicnsurf's Avatar
Originally Posted by 240M3SRT
...Its enough to wake me up when im trying to sleep(yes i sleep in my car dont ask).
that's funny. i thought i was the only one who felt that way.
mine's rock solid at idle. however, it growls at the slightest acceleration. which often turns driver heads along side me.
Old Aug 24, 2008 | 06:33 PM
Brent's Avatar
How bad the problem is really depends on your definition of vibration. Mine will give a slight quiver every so often at idle and it has done this since day one.
Old Aug 25, 2008 | 11:46 AM
roncosrt6's Avatar
Mine has a slight quiver at start up, in idle, then goes away.
How about touching the gear shift shaft?? Mine is very hot, temperature,
after driving 10-15 minutes.
Old Aug 25, 2008 | 12:23 PM
Steve Hellums's Avatar
Mine kind of had that cammed up shake in it till 800 mile's. Then I installed the RENNtech kit and it went away . But every once in a while it will give a little shake, probably from not being driven.
Old Aug 25, 2008 | 12:39 PM
BrianBrave's Avatar
<--- Huge Horsepower
11,800 miles and vary smooth at idle.
No issues when it was stock, no issues after installing mods, the tune or when using 91 or 100 octane fuel.
Old Feb 8, 2009 | 12:46 PM
jgreen's Avatar
My car has 1,200 miles on it..and it always had a slight shake at idle.. Not sure what it is.. Also not sure what dealerships are crossfire friendly here in South-East Florida..
