Oil leak Etc.
Old Aug 24, 2008 | 12:38 AM
Mr. Max's Avatar
Cool Oil leak Etc.
Bought a new 2005 srt6 last month. I noticed an oil spot under the engine on more than one occasion, yep it's oil. Somewhere online I remember someone mentioned that the oil check sensor didn't seat right and that was the cause. Does this sound familiar to any of you. Also how do you access the onboard diagnostics. I just found the codes on the forum. I read the owners manual and don't remeber it mentioning the process. I need a service manual and will get one soon. And while I'm at it an intermittant air condioner problem has arisen. Any insight? Thanks!
Old Aug 24, 2008 | 08:29 AM
huudoo's Avatar
Default Re: Oil leak Etc.
not sure on the oil leak ,
their is a recall on the transmission fluid leak though
https://www.crossfireforum.org/forum...2&d=1206095867
look here for manuals
https://www.crossfireforum.org/forum...ad.php?t=13875
Old Aug 24, 2008 | 09:23 AM
240M3SRT's Avatar
My crankshaft front main seal is leaking and im in the process of replacing it. See if theres oil under your pulley. I doubt thats your case but its free to check.
Old Aug 24, 2008 | 10:37 AM
Mr. Max's Avatar
Thanks Guys, that's very useful stuff. I have to take a friend over today to pick up his new 650 horse Mustang. Do you think he's trying to upstage me LOL.
Old Aug 24, 2008 | 10:57 AM
nox1s's Avatar
I just had the oil leak on my two valve covers, had the gaskets replaced under warranty..
Everything is going well now!
Old Aug 25, 2008 | 04:36 PM
Iamfink2's Avatar
I'm glad you got your gaskets changed under warranty after out disscussion at Woodward.
Old Aug 25, 2008 | 06:03 PM
sixshooter's Avatar
Default Re: Valve cover leak
I too have leaks on both sides of the valve covers. Very minor, just look oily. I clean them almost every month. Do you think they will replace for such a minor issue?
Old Aug 25, 2008 | 09:42 PM
nox1s's Avatar
Yes, just make sure you don't clean them so they know where the problem is and take them in.. shouldn't be a problem.
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
Sep 26, 2015 10:21 PM
stlas69
Sep 14, 2015 06:45 PM
