Fuel Pump.
Old Aug 24, 2008 | 08:00 AM
j-fire's Avatar
Default Fuel Pump.
first, i just want to thank everyone on here for being such a responsive and welcoming group, it's made the ownership experience a blast!
okay,
it sounds like the fuel pump is a common culprit on the boards, i want to replace mine BEFORE anything happens, WHICH one should i purchase? there are several choices(all SLK applications)
btw, i have a 2005 SRT with 28,000miles.....
anyone have a suggestion?
thanks.
j.
Old Aug 24, 2008 | 09:16 AM
BrianBrave's Avatar
<--- Huge Horsepower
Default Re: Fuel Pump.
okay,
thanks.
j.
Where did you hear this? - I've only read a few issues (N/A and SRT6) with the fuel pump.
Old Aug 24, 2008 | 09:56 AM
ws6vert's Avatar
I've never heard of any fuel pump problems. You may be thinking of the IC pump.
Old Aug 24, 2008 | 10:06 AM
ohnoesaz's Avatar
I had fuel pump probs, look at my post a few down for the ebay seller etc. But its rare. You're definately thinking of the heat exchanger pump, aka the IC pump. Chrysler calls it the auxilary water pump I believe.
Old Aug 24, 2008 | 10:08 AM
BlUEMDsrt6's Avatar
You definitely have to be reffering to the IC pump, because the fuel pump has never been a "common" problem with these cars. You can buy the IC pump at LET's website.
Old Aug 24, 2008 | 03:36 PM
j-fire's Avatar
good to know. thanks!
i did order the johnson pump!
Old Aug 24, 2008 | 06:33 PM
fastfunfor2's Avatar
Our SRT had a hundred miles on it last August '07 when we got it, and the fuel pump was one of several problems that needed fixing. A chech valve (or similar part) within the pump was allowing pressure to drop and causing long cranking times and hard starts. I seem to recall a few posts back then with similar hard start problems. IMO, it was the result of long term storage, not a defect. Our car sat somewhere for 35 months before we bought it. No problems in 12 months/14,000 miles on the new pump.
Old Aug 24, 2008 | 07:04 PM
Just found this thread
https://www.crossfireforum.org/forum...ad.php?t=27354
roar
Jun 15, 2022 11:46 AM
rampntlion
21
Feb 11, 2019 08:18 AM
tritongreen
Sep 18, 2015 07:32 AM
RacerXofFL
Sep 15, 2015 05:00 PM
81's
Sep 13, 2015 04:34 PM
