H&R lowering springs help
i keep hearing that the H&R springs make the car LOWER than the eibach..... BUT, the H&R kit says 1.0" front and 1.2" rear.
the eibach says 1.1" front and 1.7" rear!!!!
which kit should i use??????
According to TireRack's site. The H&R are as follows:
Front and Rear Fitment
Ride Height: Moderate Lowering
Note: Avg low 1.3"F 1.2"R
Eibachs:
Note: Avg low 1.0"F 1.2"R
NOTE: Requires the rear bump- stops to be trimmed by 20mm.
Eibachs:
If you want lowest then you have the answer, I had to pull my prosports as the front tires hit in autocross. There is a limit to what you can do. Contact Brian Brave, he cut his stockers and did it for nothing and is tickled now. A thought for you......ENJOY
WOODY
WOODY
Lookin sweet and never rub......The stock springs are stiff...stiff...stiff... Cost $0.00
what frustrates me, is different websites say different heights!!! i have seen 2 websites that say the eibach's lower 1.5 rear, and the H&R's are 1.0" and 1.2"!!!
i don't want to order a kit, install and be having 'rubbing' issues.... has ANYONE installed H&R springs on an SRT? anyone have lowering springs AND 20"wheels?
thanks everyone. i'm planning on doing the koni adjustables with it too!
Originally Posted by FP
Brian, did you cut your OEMs? You did great.....
Job was so easy I ended up re-installing the factory spring pads.....
Yup - trimmed 3/4 of a coil off the fronts and a full coil off the rears. Also replaced the rubber spring pads with the lowest dot possible.
2005 Ragtop
Oct 3, 2015 03:01 PM
Power Sedan
Sep 20, 2015 09:24 PM
