Fans always on
Old Oct 24, 2008 | 03:26 PM
smpshady's Avatar
Default Fans always on
When I turn my interior fans OFF there is still a decent amount of breeze coming out of the vents. The fans turn ON and OFF, but it almost like the engine is venting directly into the car (its not exhaust, there's no smell).
I close the vents (which substantially reduces the issue, but still present)
Any one else have this issue?
Old Oct 24, 2008 | 03:33 PM
Kit Fox's Avatar
Default Re: Fans always on
All cars after 1985(I think 85) have this. Its a safety precaution to make sure that proper ventilation always goes through the car and people dont die of carbon monoxide. Its not really on but there is fresh airflow thats gonna be pushed into the cabin.
Old Oct 24, 2008 | 04:14 PM
kingkub57's Avatar
are you turning the switch all the way to the off posistion, and are you driving the car when this is happening, or is the key completly off when this happens ???
Old Oct 24, 2008 | 04:30 PM
smpshady's Avatar
Car is on, in park, fan in off position. And the air cirulation button can be ON or OFF doesn't matter.
Old Oct 25, 2008 | 08:30 AM
kingkub57's Avatar
has the radio been changed ? either way pull the radio and check the wiring for the HVAC controll panel to make sure there is no pinched wires, there has been a lot of wires getting pinched/ worn through causing a number of problems in that area of the console. it also could be a bad controll panel, or even a problem with the cabin fan controll module
Old Oct 26, 2008 | 09:49 AM
smpshady's Avatar
It's the stock radio, and I bought the car with 4,500miles on it, but that doesn't mean that the previous owner didn't screw something up. Either way I'm taking it to the garage to see what they say.
Old Nov 1, 2008 | 12:54 PM
smpshady's Avatar
dealer fixed the issue
Old Nov 1, 2008 | 10:25 PM
cruzinquick's Avatar
Where did it actually nest?
Old Nov 2, 2008 | 05:18 AM
kingkub57's Avatar
those dam little critters they ate my car too, just right in front of the ABS module ate through 15 wires what a mess but I repaired them myself [ saving myself 1000's from the dealer ] did not set any codes and all is fine, glad you found your problem with the fan
Old Nov 2, 2008 | 05:31 AM
srt6shadow's Avatar
That's crazy.... <looks over to cat sitting on the couch>... maybe I should make his home in the garage. Don't think he would like that...
Old Nov 2, 2008 | 05:39 AM
MikeR's Avatar
I had mice making a nest right on top of my SC(see gallery) and also below the brake master cylinder behind the heat shield early this year. I got 3 mice in traps and havent had a problem since.
And dont forget +amxfire and the dog food in the muffler.
They'll be looking for a nice winter home. Start setting out your traps boys.
MikeR
Valk
Jul 12, 2021 09:49 PM
Nov 11, 2015 05:22 AM
Oct 1, 2015 01:42 AM
RiderJC
Sep 7, 2015 11:19 PM
williammt
Sep 6, 2015 11:23 AM
