Anyone try and fit 20x11???
Old Nov 8, 2008 | 10:37 AM
j-fire's Avatar
Default Anyone try and fit 20x11???
can a 20x11 fit the rear of our car? perhaps with spacers? purchasing forged 3-piece wheels next spring.
Old Nov 8, 2008 | 10:48 AM
daun's Avatar
Default Re: Anyone try and fit 20x11????
10,5 J x 20" with spacers fit on the rear axle.
8,5 J x 20" with spacers fit on the front axle.
The optimal wheel width on the rear axle is 9.5"
No body work needed.
I can sent pictures, if you are interested.
Old Nov 8, 2008 | 11:01 AM
j-fire's Avatar
pics would be great! right now i have 20x10 in the rear with 15mm spacers, and it looks great, but a 10.5 or 11" in the rear would really improve traction and the widened stance.
Old Nov 8, 2008 | 11:13 AM
MikeR's Avatar
You can put a nice fat 315 or 335 on the 9.5 wide wheel. That is 12.5" or 13" of rubber on the road. That should look pretty hefty. No need to go to an 11" wheel.
MikeR
Old Nov 8, 2008 | 01:54 PM
jonnyangel04's Avatar
MikeR
I agree the largest I went was 10.5 with and without a spacer. WITHOUT a spacer there is about 1/4 of an inch gap between the wheel and inner fender wall when the suspension is at full travel, as in the rear end jacked in the air.
Old Nov 8, 2008 | 03:25 PM
Moparrbust's Avatar
315 is the widest tire you can "tuck" under the car without sticking out and interfering with the 1/4 panel. I run 315/35 17 Hoosiers at the track on a 9'' rim.
Old Nov 9, 2008 | 09:29 AM
j-fire's Avatar
thanks for all the feedback guys. in regards to your helpful comments, are any of you riding on 'lowered springs' with such large tires?
thanks guys, truly.
Old Nov 9, 2008 | 11:54 AM
j-fire's Avatar
the big question then is: will a 20x10 wheel with a 285/30/20 tire fit on the rear axle with a 15mm spacer and the car lowered with eibach springs? the front will have 19x8 wheels with tire size not known yet... this is the forged setup i am embarking upon for next spring.
any thoughts? will it fit? thanks again!
Old Nov 15, 2008 | 04:35 AM
daun's Avatar
You will not improve traction be using rims with 10, 10.5, 11 " rims. It will look very good but it is nonsens. Look what startech has done; it works perfect. The BBS Wheels are only for show. My roadster is lowered by H&R Springs. (Front: 8,5x20 ET 38 & 5 mm spacer, rear: 10,5 x 20 ET 30mm & 15 mm spacer). If you lower the crossfire the rear wheels will be with a oblique stand (negative Sturzeinstellung). Please see fotos.
Old Nov 15, 2008 | 06:13 AM
MikeR's Avatar
Daun, those pics of your tires really show he negative camber well. Especially the one of the back of the tire and how the outside is clean and the rest is where the car's weight sits. You could install a camber kit and take some of that negative out though. Have you looked into that?
MikeR
Old Nov 15, 2008 | 08:20 AM
daun's Avatar
Daun, those pics of your tires really show he neative camber well. Especially the one of the back of the tire and how the outside is clean and the rest is where the car's weight sits. You could install a camber kit and take some of that negative out though. Have you looked into that?
MikeR
I spoke to Karmann in Osnabrück, to AMG in Alfalterbach, to startech in Bootrop and my local Mercedes Dealer. They told, that there is no possibility to
offset the negative camber on the rear axle. On the front axle I used original Mercedes Benz adjuster to compensate the negative camber.
If you have a solution for the rear axle, please tell.
(I know my English is bad; i try my best)
By the way, my name is Gerhard; i live in Daun.
Old Nov 15, 2008 | 08:32 AM
waldig's Avatar
I had bigger tires that hung out a bit and had to replace the factory springs to keep the car from squatting and hitting the tires. It looked like lots of free room but the car sat down several inches with the eibach springs. I now have an extra set of pro sport springs as with the autocrossing the tires are too close on massively HARD turns and rub so they have to go. Woody enjoy...
Old Nov 15, 2008 | 08:37 AM
MikeR's Avatar
Gerhard, I dont have a solution for you. I didnt realize that you cant use a camber kit on the back. That is too bad. I like how your wheels fit and look(except for the big tilt). Maybe some of the more knowageable wheel folks here have a solution for us.
MikeR
Old Nov 15, 2008 | 10:54 AM
j-fire's Avatar
there are crossfire camber kits on ebay, and i would also like to say, more rubber = more traction. i do not understand how you could say wider tires are silly..... it's silly to say THAT! and i do agree, it's looks very cool too!
Old Nov 15, 2008 | 10:55 AM
j-fire's Avatar
daun, here's the camber kit: http://cgi.ebay.com/ebaymotors/KMAC-...spagenameZWD1V
Old Nov 15, 2008 | 10:29 PM
daun's Avatar
Thank you for the ebay link. I will order the Camber Kit, because it is not available in Germany.
Correcting camber will allow for reduced wheel squat inner edge tire wear and improved traction. This is essential when lowering or when expensive low profile tires are fitted.
If you want to accelerate very quickly you need a differential lock and tuned ESP software. Extra wide tires make a car slowly, nevertheless they can improve traction on dry streets - correct camber assumed.
My SRT6 ist equipped with a locked differential (40%) and tuned ESP Software from VAETH ( www.vaeth.com ); the startech V8 ist equipped with a brabus 60% locked differential and 255 tires. The car accelerates great.
I m very happy to find a champer kit manufacturer. Great FORUM !
Old Nov 17, 2008 | 06:16 AM
daun's Avatar
Front 9 x 19" 235 tires
Rear: 11 x 20, 295 tires
A friends car. Looks great but a lot of body-work to do !
Old Nov 17, 2008 | 11:16 AM
j-fire's Avatar
that's EXACTLY how i want my SRT to look!!!! i'm sold on the 20x11's!!! does your friend have any 'rubbing' issues in the rear? i'm going to be purchasing ASANTI 3-piece forged wheels, and i want to be sure they will work flawlessly. i may just do 20x10.5 and use spacers.....
thanks so much for the pictures!!!!!
Old Nov 17, 2008 | 11:38 AM
JHM2K's Avatar
That is AWESOME!
Old Nov 17, 2008 | 05:00 PM
j-fire's Avatar
i ordered the rear camber kit, and have the phantom-grip pseudo-Limited Slip Differential. have not installed it yet. still waiting for my new wheels before i lower it and put on the adjustable koni shocks.
thinking of putting pirelli Pzero Rosso's on, anyone heard if these are as good as ferrari claims???
