DIY Transmission leak fix with photos... TA DAAaa
Old Jan 3, 2010 | 11:39 PM
  #41 (permalink)
HowardJ's Avatar
Default Re: DIY Transmission leak fix with photos... TA DAAaa
well, I am going to fix this little problem, but I was just going to go ahead and do a ATF change since the car is at 84K.
Old Jan 4, 2010 | 12:33 AM
  #42 (permalink)
VQ35DE's Avatar
The correct fluid is : Mopar part#
05127382AA Transmission Fluid: Sprinter and Crossfire
Coupe/Crossfire Roadster.
Old Jan 4, 2010 | 09:07 AM
  #43 (permalink)
tlppsp's Avatar
How high did you have to jack the passenger side up to avoid fluid loss?
Old Jan 4, 2010 | 09:25 AM
  #44 (permalink)
tighed1's Avatar
I went as high as my floor jack allowed. Guessing 18" or so on passenger side only.
You will need it high enough so you can get in there and work.
DON'T FORGET JACK STANDS!
Old Jan 4, 2010 | 09:41 AM
  #45 (permalink)
tlppsp's Avatar
I had the same idea but didn't know if it would work. I have the plug sitting on my tool box and my tranny isn't leaking so I haven't been in a rush to get it done. You mention using caution lining up the plug, any tips?
Old Jan 4, 2010 | 10:29 AM
  #46 (permalink)
tighed1's Avatar
DON'T make it fit!
Mine would not align so I "helped" it.
I suspect that the inner connector on my trans was already out of it's proper position and that's why I had troubles.
When I did my roadster the pieces just fell into place. Easy peasy.
Old Jan 4, 2010 | 10:49 AM
  #47 (permalink)
tlppsp's Avatar
OK.....now I have to ask. How did you realign the pins with the plug socket?
Old Jan 4, 2010 | 12:31 PM
  #48 (permalink)
tighed1's Avatar
LOL.
Are you talking about how it's supposed to work or after I "helped" it?
Without "helping" it's just a matter of aligning the connector. Worked perfect on the roadster.
If you find it won't align (you "helped" it) then you gotta drop the pan (may as well buy a new trans filter at this point) and the valve body.
This is why I sent my valve body to Builder Bill to get modified. Figured it was out might as well send it!
Old Jan 4, 2010 | 12:49 PM
  #49 (permalink)
tlppsp's Avatar
OK......Then the connector just aligns with the pins and pushes straight in??
Old Jan 4, 2010 | 04:56 PM
  #50 (permalink)
tighed1's Avatar
Yep.
Just pay attention on how it all comes out.
Reverse to install.
Old Jan 4, 2010 | 05:06 PM
  #51 (permalink)
velociabstract's Avatar
I'm real interested in how the valve body works for you. I've been looking at it since I got the car but I'm slow to experiment when I can't do the work myself. Give us the low down when it's been in there for a while.
Les
Old Jan 4, 2010 | 10:56 PM
  #52 (permalink)
HowardJ's Avatar
So should I take this stuff back or will it be fine? it says that it is NAG-1(mercedes)?
I don't know of anywhere around here that sells MOPAR ATF.
Old Jan 4, 2010 | 11:22 PM
  #53 (permalink)
VQ35DE's Avatar
Take it back. Any Chrysler dealer can get that ATF if they don't stock it .
Old Jan 5, 2010 | 06:19 AM
  #54 (permalink)
waldig's Avatar
Talking Re: DIY Transmission leak fix with photos... TA DAAaa
I got my atf at walmart, the synthetic type in mopar bottles last year. Woody Took photos in the write-up posted previously. See my galleryDip stick shown for the diy'ers
Old Jan 9, 2010 | 03:24 AM
  #55 (permalink)
HowardJ's Avatar
What in the hell and I doing wrong???
I CANNOT get the electrical connector in the new shell.
I have been trying I **** you not for 2 hours! I have to worst headache ever this is so freaking frustrating.
I have removed the new shell and tried putting it back in. I pushed it in, After the second time I pushed as hard as I could and it didn't move anymore, so it HAS to be as far as it will go. I can get the new shell in and lined up and all but the electrical connector will NOT fit!
WTF am I doing wrong???
Grr.
Old Jan 9, 2010 | 08:13 AM
  #56 (permalink)
waldig's Avatar
DID you try to insert the old one for an alignment check of the parts??Woody
Old Jan 9, 2010 | 03:51 PM
  #57 (permalink)
HowardJ's Avatar
I got the connector back in, finally. -_-
But I think my dad's puppy ate the T27 bolt for the heat shield. grand.
I blocked off the whole car to where the dog couldn't get to it, and dad moves everything in the morning.
My dad also knocked the wooden ramps onto my door leaving 2 very nice dents.
Old Jan 9, 2010 | 04:11 PM
  #58 (permalink)
MikeR's Avatar
If the puppy ate it..... you'll get it back..... just wait!
Old Jan 9, 2010 | 04:14 PM
  #59 (permalink)
HowardJ's Avatar
hah. that's what i'm afraid of.
Old Jan 9, 2010 | 04:19 PM
  #60 (permalink)
MikeR's Avatar
If it was my puppy I would wait for it to poop out, wash it a little(maybe), hand it back to you and say I found it on the floor.....
whats a little poop between family???
