Code3 Pulley size question
Old Jan 11, 2009 | 05:48 PM
  #41 (permalink)
BrianBrave's Avatar
<--- Huge Horsepower
Default Re: Code3 Pulley size question
Originally Posted by tom2112
I can't really say anything about the plugs, as I don't really understand what they do for you.
Hey Tom -
Here's a good read about spark plugs.
It's not always about racing and it's not just about the spark.......
Old Jan 11, 2009 | 06:34 PM
  #42 (permalink)
ohnoesaz's Avatar
The johnson pump might not do too much bceause the stock system is restrictive... More pumping power but still pushing against a restrictive system. Maybe search back through Waldig's extensive posts on the heat exchanger studies and upgrades.
I eventually found my winner by keeping the stock pump but parallel'ing a second heat exchanger with the stock heat exchanger. Basically when the pump output hits the restriction limit of the stock exchanger it just spills over to the second exchanger and both exchanger outputs unite before reaching the intercooler above.
Old Jan 11, 2009 | 06:48 PM
  #43 (permalink)
BrianBrave's Avatar
That's not really true - I have two stock HE's in my backyard and I can push water thru them with the garden hose with the greatest of ease and pressure...
Old Jan 11, 2009 | 07:23 PM
  #44 (permalink)
cruzinquick's Avatar
Originally Posted by lacerdaschoon
A quick question. Is it worth to buy NGK spark plugs and LET spacers? OR more so a mod you add when u run high boost? In response to how i drive my car, This car is my daily driver, i dont know enough about modding so im not keen to be forking out $ on problems and issues. I will be voiding my warranty so i would like to be as reliable as possible. I dont do track racing, all i want is extra noticable power to have fun with. Thanks for all your suggestions.
I do race every weekend. I probably have more passes than everyone here combined. My mods are in my signature, but what it doesn't say is I have my stock untouched exhaust, stock untouched plugs, wires, ignition, stock untouch cooling system. I live in AZ the hottest state in the country. If you mod correctly you won't need to waste your money. I don't drive mine everyday but can tell you I have raced in 40 degree to 110 plus degree weather with no issues. My opinion is plugs are only necessary to change if you run nitrous, cooling upgrades are for autocrossing, exhaust modifications for your own ears. The safest place for a modded car is the track, the street is not for racing. Not with how fast this car is or will be when you done modding.
Old Jan 11, 2009 | 09:24 PM
  #45 (permalink)
BLKFIN's Avatar
ADDICTED TO BOOST
Originally Posted by tighed1
I have a Code 3 and a 181. With the C3 I only saw a 1 to 1.5 pounds of boost increase.
Below shows what I have seen in my car (here at 4700ft).
Stock Pulley 13-14 lbs of boost
Code 3 15 lbs
181 17 lbs
Code 3 & 181 19-20 lbs
I am curious why some of you see such low boost levels with a Code 3. I see 17lbs in first and second gear and 18-19 in the top of third. I also have no belt slip to speak of. I do have one of the first generation pulleys without the continuous groves....I wonder if that makes a difference??
My 12.2 was with my car weighing exactly 100 lbs more than 240M3SRT and sowardcustoms SRT6's due to all the stereo equipment in the hatch. It may have helped to have the extra weight back there to offset some wheel spin.
Old Feb 9, 2009 | 11:55 AM
  #46 (permalink)
rcompart's Avatar
Just for reference, what are the stock crank and supercharger pulley sizes?
Old Feb 9, 2009 | 10:56 PM
  #47 (permalink)
Forza1's Avatar
74mm and 155mm
Old Feb 10, 2009 | 03:52 AM
  #48 (permalink)
ws6vert's Avatar
Wow! Now who to believe.
Old Feb 10, 2009 | 10:28 AM
  #49 (permalink)
mrphotoman's Avatar
Originally Posted by Forza1
74mm and 155mm
lol
74mm stock and 62mm code3 if i remember correctly.
Old Feb 11, 2009 | 10:12 AM
  #50 (permalink)
Voyager's Avatar
the 155 was answering his question to the stock crank size. mrphotoman
Old Feb 11, 2009 | 10:18 AM
  #51 (permalink)
rcompart's Avatar
I gotcha Voyager.
Old Feb 11, 2009 | 01:35 PM
  #52 (permalink)
mrphotoman's Avatar
oh okay, my bad.
Old Apr 9, 2009 | 12:11 PM
  #53 (permalink)
jgiraldo's Avatar
i'm bringing this thread back, i'm at a point where i think i want to mod my 2year old srt6. just graduated college, making a little money, but don't want to spend a lot since i want to do other things (house).
Basically should i do a CAI or a pulley. I don't want to mod my car that much, if any, but it seems like for 300 bucks on a cai i can gain 20 horsepower it's definetly well worth it.
I've taken my car to the track once, i live autocrossing more than the 1/4. Ultimately i want to take my car to the texas mile just so i can go fast. it's my daily driver.
What should i do? CAI, pulley, or nothing?
Old Apr 9, 2009 | 12:33 PM
  #54 (permalink)
///SilverSaphRT6's Avatar
Go with the CAI first.....and enjoy that power....once your smile gets a little bland then pulley that ****....that's the route I'm going to take atleast. I just dont want belt slippage is what's keeping me on the fence right now about pulley.
Old Apr 9, 2009 | 12:47 PM
  #55 (permalink)
bombsquad56's Avatar
Definitely go with a CAI first. And regarding the CODE3 pulley, I have no obvious belt slippage issues.
Old Apr 9, 2009 | 12:54 PM
  #56 (permalink)
ohnoesaz's Avatar
You need a CAI to open up the airflow. The stock intake has crimps back towards the throttle body, it simply cannot allow enough air through.
Then you need a pulley mod of some kind that will spin the supercharger faster and create more boost.
After that you can be more creative... A computer tune, maybe exhaust work, maybe modify the cooling system, theres plenty of ideas.
But hey, just a word of advice. I completely regretted modifying my srt-6. It became expensive and time-consuming. I know people will disagree but its my own personal experience. So make sure you're truly bored with your car before you start modding because if you're just bored with life in general then put your money into some other hobby instead of the srt-6. Its just my personal opinion though... I regret modding my srt6 which is now gone, and regret modifying my '05 mustang gt which is long gone. Lesson learned for me.
EDIT: Oh yeah, I used a 100mm idler to tighten up my belt after installing the code3, so if you have belt slippage then thats an option. I don't believe I had any slippage in the first place though.
Old Apr 9, 2009 | 02:03 PM
  #57 (permalink)
I know what you mean...I have a 94 gt for sale now that I put 11 grand(reciepts showing) along in custom engine build which has been sitting for 2yrs only having 800 engine break-in miles. The car is just sitting because it got like 10 miles to the gallon after completing. A big regret ever since...that's why I wont modify this one too much
Old Apr 9, 2009 | 04:13 PM
  #58 (permalink)
cruzinquick...well said...until something begins to fail, pump etc....I am running stock except for a few mods...now we can't all get on the track as I have recently found out the hard way...should have bought a coupe...'cause the 'vert is destined for street racing....well, controlled street racing, well sorta....LOL
Old Apr 9, 2009 | 05:50 PM
  #59 (permalink)
lacerdaschoon's Avatar
Oledoc2u why cant you go to the track? Cruzinquick i didnt realise you live in the hotest state and stil get sub 12. I know you dont like the 185s but id love to see what times you could get with one
BrenLW
Aug 5, 2015 04:53 AM
onehundred80
Canada
Jul 24, 2015 03:50 PM
crymar
Jul 17, 2015 08:46 AM
2004_
Jul 13, 2015 02:04 PM
syfi
Jul 12, 2015 05:59 PM
