mystery 'whirrrring' noise at stoplights...
Old Feb 5, 2009 | 09:11 PM
j-fire's Avatar
Default mystery 'whirrrring' noise at stoplights...
can someone please tell me if it is 'normal' to hear a strange 'whirring' noise every time i stop at a stop light? if i'm sitting at a complete stop, after a second or two, the noise starts, like the sound of a small power drill starting under the hood? the sound only lasts for about 5 seconds.
normal? cooling mechanism? pump? fan? secondary water pump? paranoid?
Old Feb 5, 2009 | 09:48 PM
ProjectMayhem's Avatar
Default Re: mystery 'whirrrring' noise at stoplights....
mY gues is the radiator fan when they get going they can be quite noisy.
Old Feb 5, 2009 | 10:31 PM
manisusmc's Avatar
does the str6 have the recirculation exhaust pump like the limited does?
Old Feb 5, 2009 | 11:43 PM
Wedge's Avatar
Every once in awhile I also hear a whirring noise that only lasts a few seconds when stopped, mostly when I pull into my garage. I think I read something about this before and the opinions were that it was normal.
Old Feb 6, 2009 | 06:09 AM
BlUEMDsrt6's Avatar
Hmmmm, try calling out the name KIT and see if you get an answer back.
Old Feb 6, 2009 | 06:12 AM
ImportLabSRT's Avatar
Air injection pump.... nothing to worry about.
Old Feb 6, 2009 | 09:16 AM
j-fire's Avatar
THANK-YOU!
Old Feb 6, 2009 | 09:23 AM
crossfirefun's Avatar
What he said...happens all the time,completely normal.
Old Feb 6, 2009 | 03:23 PM
ws6vert's Avatar
It's all good....
Old Feb 7, 2009 | 02:37 PM
ohnoesaz's Avatar
Now, let me just add... Isn't it abnormal for this to happen all of the time? Or even when the car is hot? I thought it was meant mostly for when the car is cold, the first few stop lights, the first 10 minutes. After that I have never ever heard the injection pump whir.
Old Feb 7, 2009 | 02:40 PM
j-fire's Avatar
So..... If this is the case, what likely needs to be replaced, fixed etc???
Old Feb 7, 2009 | 04:06 PM
manisusmc's Avatar
if something was wrong with it it will throw an engine code i think its p1040
Old Feb 7, 2009 | 04:14 PM
Kit Fox's Avatar
OP, your fine, its normal.
Old Feb 7, 2009 | 11:28 PM
Ringmaster's Avatar
That's strange, because my car is just the opposite. I only hear it after the car warms up.
Old Feb 8, 2009 | 04:45 AM
yanni2112's Avatar
I only hear it for the first 30 seconds WHILE the car is warming up. Base model, do they share some of the same parts?
Old Feb 8, 2009 | 06:52 AM
REVIT93RX7's Avatar
This sounds completely normal. If I listen sometimes I hear it when stopped.
Old Feb 17, 2009 | 01:25 PM
SRT6nTulsa's Avatar
It does seem to happen at the same time as the red light. Does anyone know what the red light does?
Old Feb 17, 2009 | 05:47 PM
This will happen when ever the M.E. sees a low oxygen level in the exhaust stream. It adds air to lower emissions.
Old Feb 17, 2009 | 06:06 PM
Thomas B. Whyle's Avatar
Don't let paranoia get the best of you: Drive and enjoy the car, if you spend your time waiting for something to go wrong, you miss the whole point of owning a Crossfire. It has been my experience that our cars (with the proper care) are fairly trouble-free. If something were to go wrong, the car has a fairly extensive collection of warning systems to let you know. When something breaks, you fix it ....otherwise drive on, TBW
ty_ty37
Jun 27, 2024 10:42 AM
Steven 4190
Nov 25, 2015 10:12 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
RacerXofFL
Sep 15, 2015 05:00 PM
