TPS voltage???
Old Apr 10, 2009 | 04:01 PM
SRTpowa's Avatar
Default TPS voltage???
I am in the process of installing my window switch. I am getting .7V with the car off and when I press the gas it goes to 1.1V at WOT? Is this right? When I turn the car on at idle I am reading .6V?
I don't know if I have a bad connection or if this is just the way it is?
Can anyone offer some help.
Old Apr 10, 2009 | 04:21 PM
SRTpowa's Avatar
Default Re: TPS voltage?????
Well that isn't right. The solenoids are clicking as soon as I touch the gas. Something isn't right. If anyone knows the proper voltage range let me know thanks.
Old Apr 11, 2009 | 08:44 AM
SRTpowa's Avatar
Well I don't think I'll be spraying any nitrous today. Getting ready to go to the track and I just don't have the time to troubleshoot and properly test the system. My new belt wrap kit that Brandon overnighted me should be here by noon. I'm slapping that on and making the 2 hour drive east to Twin Cities dragway in Monroe Louisiana. Hopefully I can pull some 11's without the nitrous.
Old Apr 11, 2009 | 09:42 AM
NeedsWings's Avatar
we have 2 tps wires, they both run parallel voltage. i was hoping the second one would be the WOT voltage as the pedal passes the kickdown threshhold but that wasnt the case. let me dig up an old zt-2 log and ill be able to show ya the actual voltages....
Old Apr 11, 2009 | 11:28 AM
SRTpowa's Avatar
yeah I tapped the yellow #21 wire as directed on your site? I'l have to figure something out later. I'm off to the track. Let me know if you have any ideas.
Thanks.
Old Apr 11, 2009 | 11:55 AM
cruzinquick's Avatar
Good luck at the track. I've checked my logs but the TPS is being recorded in % not voltalge. Idle is 2-7 and WOT is 99.
Old Apr 11, 2009 | 04:43 PM
NeedsWings's Avatar
https://www.crossfireforum.org/forum...9&postcount=25
Old Apr 11, 2009 | 05:03 PM
waldig's Avatar
Wink Re: TPS voltage???
I must have been dozing, what is the question here? Are we trying to get a throttle position switch signal??
If the wot signal is wanted, I would look to the kick down switch on the pedal ==some call it the warp switch.
Woody doing the weekend
Old Apr 11, 2009 | 11:13 PM
SRTpowa's Avatar
Any Idea wher that wire runs in the ECU box?
Worse case scenario I'll have to run another wire inside the car.
blackpepper
Oct 4, 2017 06:09 AM
axnguyen
Jul 21, 2015 11:41 AM
bdh
Jul 9, 2015 09:40 AM
tylerxfire
Jul 3, 2015 05:32 PM
BlueStorm
Sep 4, 2008 06:54 PM
