stupid rim question
Old Apr 12, 2009 | 10:28 AM
carpen04's Avatar
Default Re: stupid rim question
yea i have seen his work..it looks awesome
check this site i have a few questions
http://www.1010tires.com/wheel.asp?w...lbrand=Mandrus
1. what in the world is offset and where should i be between? (# offset)
2. i like lips so 20's by 10.5 or 11 to big for the car..i dont want it looking crappy but look bulky without the spacers?
3. what is your size in the back?
thanks boys
Old Apr 12, 2009 | 02:39 PM
j-fire's Avatar
my front offset is +32 with no spacers on a 19x8.5" wheel. i
my rear offset is +25 with 10mm spacers in the rear just to make it sit more aggressive. i am now wishing i had gone EVEN WIDER with the rear tires, i truly think a 295 would have easily fit back there, and i may even try a 20x10.5" rim and 305/30 tire with a 12mm spacer next year.
i did undergo the task of fitting larger tires than usual in the front and rear. the 235/35/19's up front were the most trouble after lowering, but setting the camber helped pull the meat away from the suspension. you have to get her on a lift and just see what can be removed, replaced or hammered and smoothed out. i used a hammer and a zaw-saw quite a bit! really won't take much time either. i also removed a lot of weight from my rear hatch so i could make the rear tires flush with the rear fenderwells without hitting them on big bumps.
because i chose such an expensive tire for the car, i knew i'd be annoyed by uneven wear caused by not setting the camber. food for thought.
btw, the pics of my car DO NOT do it justice, i will post some new pics soon. the lip on my rear wheels is 4-inches wide, and the car looks way more aggressive than appears. the H&R drop is a bit lower than the eibach drop too.
Old Apr 12, 2009 | 05:49 PM
cgocifer's Avatar
My sizes are:
Front: 19x8.5 with an offset of 32. Tires are 225/35/19
Rear: 20x10 with an offset of 30. Tires are 275/30/20
No spacers.
Old Apr 12, 2009 | 07:16 PM
carpen04's Avatar
hey guys if you check the site in my last reply
would the 20 by 11 with a 3 Inch lip look good or look bad..i figure bigger lip you wont need spacers to make the car look more aggressive..
i know i will get a 19 front with a .8 or 1 lip but the back i have problems..
yea jfire if you could get bigger pics focused on the back rim more would be great..thanks guys
Old Apr 12, 2009 | 08:08 PM
Montana Crossfire's Avatar
Aren't 305/30's going to be way to tall for that application?
Maybe I am reading this wrong but thats going to be over a 3 1/2"
Tall side wall.
What ever...
Mike
Old Apr 13, 2009 | 02:51 PM
carpen04's Avatar
i am not sure what you are looking at buddy..sorry
Old Apr 19, 2009 | 08:21 PM
forjox's Avatar
I bought this SRT6 Roadster last year. Had these TSW Laguna's when I got it. P1010325.JPG
Old Aug 30, 2009 | 03:30 PM
donedharm's Avatar
How about these?
Old Aug 30, 2009 | 07:34 PM
m3pig's Avatar
Stern on my SSB......don't need spacers. Eibach lowering........295x30s on the back
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
