Christmas in May! (courtesy of Needswings)
These are arriving this week for me (including a supercooler)- I'm really excited! Wait till you see Chris's set- it's ALL BLACK. Talk about Darth Vader's car!.....
Good luck!!
Originally Posted by BlUEMDsrt6
I didn't realize the dual NW intakes were in production. Wonder what the dual puts down compared to the single?
I'm more curious about placement. I know the single goes through he front where the old one fit in to...but the drivers side of that is nowhere near the same...much smaller. seems like it would need some significant modifications to fit in there...or a different placement.
I designed the dual with 3" hose fitinto the space on the driver side, Rob revised it to be 2 3/4" and it fits better.
On the same dyno I ran the dual with a baggy over the second filter and then tested it with the pair of filters running in parallel. I got 1 PSIG more boost, and 35 hp on the bottom end, below 2500 rpm. at the top I got 7 hp overall but the bottom end really carries the car faster off the line and it makes a big difference. The restriction in a single filter and 3" pipe was 30" of water at WOT or the 1 psig.
I had posted the dyno charts and will try to get the photos inserted below. It really runs stronger, but there will be several others soon enough to sing that song.
What tickles me is that Rob after I disclosed the next modification which Iam making now; has agreed that it is going to actually increase the motors breathing 40% over what he is running on his car today. Ill dyno that and the Eurocharged 185 very soon to show what each can produce. The 178 dyno was 347 rwhp for a baseline measurment. And no this is not another stellar battery project, that is reserved for April 1st.
W00DY
W00DY
Originally Posted by bhays
Very nice. Can't wait to see it installed. If I could be so bold, what was the approximate damage?
Are you going to be getting a tune with that new set-up woody?
Looks like that's all your missing. Would be intrested to see your times now once you have everything settled in and ready to go.
W00DY
W00DY
W00DY
W00DY
Now, just imagine if you had two huge, less restrictive air-filters and took advantage of ram-air the intake openings provide and your tubes weren't so darn hot.
If you enjoy the added HP at the bottom end now, wait tell you get that 185mm installed.... you'll get 10-15 more HP at the bottom and 20-25 more at the top.
Then a tune.
Enjoy....
i'm installing the dual CAI's from NeedsWings tomorrow, and doing DYNO runs with my new revised tune from inMotion on friday. i will be sure to post the results.
i had my dual CAI's done in black to match my black valve covers and black intake manifolds, it all looks BEAUTIFUL! i'll post pics!
Originally Posted by mrphotoman
i bet that does look really good, do you have a before dyno to compare to?
stay 'tuned' pun-intended.
Very nice cross hair. When are you getting your InMotion tune? You and Distant are going to set some records this spring.
Looks like the MB race day at MIR is going to be rescheduled again, you guys should try to make it.
Jfire your setup is killer as well. Can't wait for some more 11 second club members.
