Black dust :(
Old May 15, 2009 | 09:51 AM
aussiedude's Avatar
Default Black dust :(
just changed my belt, and now have black dust in the engine compartment
is this ALWAYS an indicator of belt slip, or might there be some kind of wear in on the new belt?
Old May 15, 2009 | 10:07 AM
SRT6nTulsa's Avatar
Default Re: Black dust:(
I have a little bit of belt dust on my engine cover. I was a little concerned about it, but after a quick visual inspection, it looks as if the belt runs true. Does anyone else have a little bit of belt dust on their engine covers?
-Alex
Old May 15, 2009 | 10:13 AM
Are you sure you have the belt correctly lined up in the grooves in all of the pulleys? The belt could be offset and rubbing against something or the offset will flex the belt side to side and cause rapid wear.
Is the tensioner giving the correct tension, if the new belt is too long it will slip without the correct tension.
Old May 15, 2009 | 12:12 PM
Montana Crossfire's Avatar
According to manufacturers the black powdery substance does show signs of slippage though often it is minimul it IS slippage.
Which belt did you go with?
As I think I heard in the past you are running a code 3 pulley aren't you?
Mike
Old May 15, 2009 | 12:16 PM
huudoo's Avatar
when i first got my car ,
i took the engine cover off and i could see a little black belt dust.
Old May 15, 2009 | 12:48 PM
tom2112's Avatar
She can ride with me ;)
I second the comment about checking your belt alignment. If it is off by one groove on the supercharger pulley it will eat up the edge of the belt and throw black dust everywhere.
Old May 15, 2009 | 08:49 PM
apkano's Avatar
Life is random...so am I.
That would be the first thing I'd check.
I guess that means I "third" it.
Old May 15, 2009 | 10:06 PM
well, I lost the engine cover a long time ago, but I run the crap out of mine, without belt dust, so I fourth it.....
Valk
Jul 12, 2021 09:49 PM
TerryR
Dec 13, 2019 03:27 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
JEFASOLD
Sep 28, 2015 12:10 PM
ritous1
Sep 26, 2015 01:27 PM
