Are our brakes the same ones as on the slk32?
Old Aug 12, 2009 | 03:06 PM
32krazy!'s Avatar
Default Re: Are our brakes the same ones as on the slk32?
if someone will post a foto of the srt-6 front caliper i can tell you if it is the same as my slk32.
ok did a foto search and brian braves fotos are the same calipers as are on my slk32. hope this answers your question
Old Aug 12, 2009 | 03:09 PM
msheredy's Avatar
I'd be tempted to go for these.
Old Aug 12, 2009 | 03:14 PM
MikeR's Avatar
I'd have to go rob a bank first!!
Old Aug 12, 2009 | 04:40 PM
tubbypoo's Avatar
Calipers as oem on SLK32 are two piston on the back of the caliper that pulls the front on to the disc.(two piston sliding). I think they are the same calipers as w208 clk55 (the first one) as this was also based on the Mercedes C Platform and running gear.
Old Aug 12, 2009 | 05:50 PM
BLKFIN's Avatar
ADDICTED TO BOOST
Correct, they are the SAME.
Old Aug 12, 2009 | 06:09 PM
msheredy's Avatar
Really? I thought these were priced pretty well considering they have 8 pistons. Stoptechs are anywhere from 1900-2800 and I think those are only 4 pots.
Old Aug 12, 2009 | 07:03 PM
aussiedude's Avatar
well this is all rather interesting...
Krazy,
can you answer the question about the transmission?
On yours, if in manual mode, does it upshift for you at redline, or does it wait for you?
Old Aug 12, 2009 | 08:42 PM
32krazy!'s Avatar
Krazy,
if i have my car in manual mode with the traction control turned off and redline at 6100 rpm the engine the trans will upshift for me whether i want it to or not. if its in auto the shifts occur much sooner than the redline.
Old Aug 12, 2009 | 08:53 PM
MikeR's Avatar
It is not that they are priced bad...just too much for me. I have been looking at a used set of front and rear C32 AMG calipers and rotors for $800. The C32 is a 345mm rotor, ours is a 330mm. Plus the C32 is a 4 & 2 piston.
edit: Sorry, I didnt mean to hijack your thread. Back on topic.
Old Aug 12, 2009 | 09:00 PM
32krazy!'s Avatar
here ya go mike. fronts for 650$
F.S:C55/c32 Complete Front brake kit - MBWorld.org Forums
i think the rear c32 is the same as yours
Old Aug 12, 2009 | 09:06 PM
MikeR's Avatar
Thanks 32... that is a good choice too...
Old Aug 12, 2009 | 11:51 PM
ckovach's Avatar
OK, so the conclusion is that they are the same.
I believe the SLK55 has 18s so the calipers should fit fine on the x-fire. Lots of C32s have upgraded to them (along with upgrading to 18s), too.
RamblinShamblin
Aug 12, 2017 10:55 PM
Oct 1, 2015 01:42 AM
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Sep 25, 2015 07:46 AM
