What is this line ? help
Old Aug 29, 2009 | 07:25 PM
hcarter's Avatar
Question What is this line ? help
Located at the rear of the driver side of the Engine ,Looks like it connects to the rail , the hose needs to be replaced it's cracked ,but I'm not sure what to order ,looks like a high pressure hose
THANKS !!
Old Aug 29, 2009 | 07:29 PM
32krazy!'s Avatar
Default Re: What is this line ? help
foto wont enlarge cant see what you are looking at
Old Aug 29, 2009 | 07:36 PM
hcarter's Avatar
Old Aug 29, 2009 | 07:58 PM
waldig's Avatar
Talking Re: What is this line ? help
That would be the PCV hose that vents oil vapor to the bottom of the throttle body to be burned. No pressure, just the old fashioned vent hose for fumes. Woody
Goes to the needswings cai on the passenger side, note hose clamp, not fuel.
MikeR's Avatar
That is the line feeding the fuel rail. Crossfire service manual page 14-33.
Crossfire parts manual, figure 14-310, item #10, Fuel Hose, 05099000AA,looks like the correct one. You should double check to be sure.
Old Aug 29, 2009 | 08:03 PM
MI1XFIRE's Avatar
You are both correct but I believe he is referring to the fuel supply line
Old Aug 29, 2009 | 08:07 PM
MikeR's Avatar
The fuel line looks like it is cracked.......but maybe that is jus the sleeve.
Old Aug 29, 2009 | 08:08 PM
hcarter's Avatar
Yes it's the one under the 5/8 Hose ,,,it has a pretty nasty crack in it and needs to be replaced
Do I need to bleed the presure off the system before I remove the line ???
Thanks for all the quick responce ,,,,,,
Old Aug 29, 2009 | 08:14 PM
MikeR's Avatar
YES. You need to download the servce manual and parts manual from the SRT6 forum. Here is the fuel rail removal procedure.....
1. Disconnect the negative battery cable.
2. Remove the air cleaner housing.
Refer to Page 9-608.
3. Remove the fuel rail trim panel screw and then remove the fuel rail trim panel (1).
4. Release the fuel pressure through the fuel rail service valve (7) using a fuel pressure tester. Collect the fuel in a
suitable container.
5. Disconnect the fuel feed line (3).
6. Remove the fuel injector wire harness connector retaining clips and then disconnect the fuel injector harness (6)
from the fuel injectors (4).
7. Remove the fuel rail retaining bolts (8).
8. Remove the fuel rail (2) with the fuel injectors (4) by moving the fuel rail (2) side to side while lifting upward.
9. Remove the fuel injector retaining clips and the fuel injectors (4) from the fuel rail (2).
Old Aug 29, 2009 | 08:26 PM
hcarter's Avatar
It looks like I can just replace the line it has fittings at both ends and is only about 6 or 8 inches long and its out in the open not restricted ;
just wanted to make sure about the pressure,,,,, I actually found this problem while installing a Needswings CAI
Again Thanks for all the info...
Old Aug 29, 2009 | 08:41 PM
GDC-SRT's Avatar
Just be sure to relieve the fuel line pressure before.
suitable container.
Valve is on the passenger side,front end of rail.
Old Aug 29, 2009 | 08:56 PM
hcarter's Avatar
Great Thanks
Old Aug 29, 2009 | 10:52 PM
tighed1's Avatar
Love it when a thread goes like this.
Member asked a question.
Multiple members provided information to assist.
Original question is answered.
Nice job Guys!
Old Aug 29, 2009 | 11:07 PM
Another way to release pressure, that is on most cars:
Pull the fuse for the fuel pump or fuel pump relay. Start and run car until it dies. No pressure.
James
syfi
Mar 28, 2026 04:14 PM
RamblinShamblin
Aug 12, 2017 10:55 PM
JEFASOLD
Sep 28, 2015 12:10 PM
tritongreen
Sep 18, 2015 07:32 AM
