oil leak again?
Old Sep 26, 2009 | 01:13 PM
jsaredwings's Avatar
Default oil leak again?
I had my SRT serviced, covered under warrantee back in May due to a oil leak, they determined it was the valve cover gaskets and repaired whatever they needed to do, the factory warrantee expired at the start of july and earlier this month i started to notice oil spots on the driveway again, turns out its my car, again. Oil change was done before the warrantee work, driven approx. 3000 miles since then. Any idea if repairs are covered for a period of time after done? Other common problems out there?
Old Sep 26, 2009 | 01:42 PM
billvp's Avatar
Default Re: oil leak again?
most dealership work has a 12/12 warranty on it, so you should be fine. If you have the paperwork still, the info may be on it. Otherwise, call them and ask. I'd think you are still covered, if it's the same problem of course.
TerryR
Dec 13, 2019 03:27 PM
minimayhem
16
Aug 23, 2016 07:47 AM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
