What would cause sudden surges?
Old Sep 28, 2009 | 03:53 PM
Default What would cause sudden surges?
This happens to my SRT-6 on occasions. I'm cruising along the highway with the cruise control off at about 70mph and the car does a sudden quick surge forward. It's significant enough to jerk my head back. But it only last a second or two then goes back to normal. This happened to me twice over about 100 miles this weekend.
What do you think would cause this?
Old Sep 28, 2009 | 03:55 PM
GatorLCA's Avatar
Default Re: What would cause sudden surges?
I/C pump going out.. do you notice a lack of power after it happens?
Old Sep 28, 2009 | 04:18 PM
tighed1's Avatar
Mine does that every time I step on the gas!
Old Sep 28, 2009 | 05:12 PM
No, no loss of power after it happens. I thought it could be the I/C pump. But figured a sign of it going out would be a drag of power instead of a surge.
There have been other times when I've noticed a loss of power on the highway but thought it was more heat related.
Old Sep 28, 2009 | 06:02 PM
msheredy's Avatar
I remember driving around when my pump stopped working and it would do that on my way to work and back. It was especially noticeable going up a grade.
Old Sep 29, 2009 | 10:10 AM
ZAHANMA's Avatar
+1000000
Surging usually indicated I/C pump going bad...then again, when mine did it I replaced the pump and it was still doing it...finally turned out to be a bad ambient air sensor....but I would change the I/C pump first.
Old Sep 29, 2009 | 10:15 AM
tighed1's Avatar
Looks like the key word here is "surge" not loss of power (I'd say NOT the I/C pump in this case).
When you figure out what it is maybe we can figure out how to make it "surge" all of the time for a power boost!
Old Sep 29, 2009 | 01:53 PM
Goldwing's Avatar
When the i/c is failing/fails, the car does surge when it causes the supercharger to disconnect. However an attempt to accelerate hard at that point will result in no power, no acceleration. If the i/c problem is intermittent there will be a noticeable slow down when the s/c cuts back in. This is actually the drag caused by the s/c clutch re-engaging.
Old Sep 30, 2009 | 09:57 AM
Deevcj's Avatar
Sounds just like my I/C pump. I thought it was a tranny problem. The Super would kick in and right out again due to high temps. Easy fix, better than a new Supercharger for $7200...
Old Sep 30, 2009 | 04:53 PM
Andy G's Avatar
Are you running a Sprint Booster?
Andy G
Old Sep 30, 2009 | 05:21 PM
Andy G
No. Only performance mod is the Needswings CAI. It had the same problem before the CAI.
I'm going to go ahead and put on a Johnson pump.
Kodebuster
Nov 5, 2020 04:06 PM
northwest_crossfire
May 30, 2016 05:19 PM
cx24724
Jul 12, 2015 11:57 AM
Kv1ck
Jun 8, 2015 07:25 AM
msheredy
Jan 16, 2007 07:23 PM
