Noise!?!?!
Old Oct 10, 2009 | 08:15 PM
slow4dr's Avatar
Default Noise!?!?!
I am getting a noise from the front of the car, engine or trans?, it is a squeak around 1.5-2k going into 2nd gear.
Mods are NW intake and Code 3 Pulley.
Thanks for any input.
Old Oct 10, 2009 | 08:50 PM
jturkel's Avatar
Default Re: Noise!?!?!
could you provide a sound clip or video? do you get it while idling in park or only when driving?
Old Oct 10, 2009 | 09:00 PM
slow4dr's Avatar
Only while driving when the car shifts from 1st to 2nd, I will try and get a video up tomorrow. It only does it when the car is cold after driving for a few minutes it goes away.
Old Oct 10, 2009 | 09:14 PM
sounds like bearning. on pully or idler. jim
Old Oct 10, 2009 | 09:20 PM
Ringmaster's Avatar
Mine does the same thing. It is a small "chirp". You are not alone.
https://www.crossfireforum.org/forum...when-cold.html
I don't know if anyone has found an official cause or repair, or if anyone
has actually experienced supercharger failure after hearing this.
jturkel's Avatar
Originally Posted by amx1397
sounds like bearning. on pully oir idler. jim
if the bearing is going bad, you should hear it while in park when not moving in addition to while driving.
i just replaced mine.
Old Oct 10, 2009 | 09:25 PM
slow4dr's Avatar
THAT is exactly it, thanks for the link. I guess I should have searched first.
Old Oct 10, 2009 | 09:31 PM
slow4dr's Avatar
Another question for the knowledgeable:
I had my valve cover leak fixed at the local Dodge dealer, well since I own the only srt-6 in Caldwell County they don't work on them much, needless to say it is leaking again. Is there any tips that I can give them so they get it on right if I take it back, or I might just take it to a friend that is a mechanic. Does anyone know how much the seal cost and is that all I would need.
Old Oct 10, 2009 | 10:23 PM
Ringmaster's Avatar
try this:
https://www.crossfireforum.org/forum...-8k-miles.html
Old Oct 11, 2009 | 05:31 AM
crossfirefun's Avatar
I have the squeak and needed to fix both little covers on mine @ 2000 miles.
ty_ty37
Jun 27, 2024 10:42 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
pop49
Sep 30, 2015 11:14 AM
RacerXofFL
Sep 15, 2015 05:00 PM
