Leaning out issues
Old Nov 28, 2009 | 09:23 AM
Xray's Avatar
Default Leaning out issues
I have attached a couple of my data logs. I am really getting frustrated I just had a new tune flashed and they put the same one they did on bulldoggers yet I am still going really lean on the top end. I would appreciate any suggestions.
Old Nov 28, 2009 | 09:30 AM
Buggin's Avatar
Default Re: Leaning out issues
Not that I'll be of much help probably, but I'm not seeing any data logs.
Old Nov 28, 2009 | 10:08 AM
distantpulse's Avatar
Originally Posted by SRT6 Gang Member
If I recall correctly, Bullgoggers upgraded his fuel pump to an SL55. Unless you did the sme, his tune would not correct your leaning issue, since you would not have the same fuel flow rate.
Yes, I was also going to say this. You are correct.
Old Nov 28, 2009 | 10:13 AM
Xray's Avatar
Good to know I did not know he had upgraded his fuel pump. It is even running about 18 AFR at idle in gear. This just started last night. I have put some lucas fuel treatment in hoping maybe a fuel injector or 2 have started to clog. I am getting a dyno tune in atl in dec so hopefully I can get this fixed. I must admit I am frustrated I finally got the car to hook up and got some good launches but because of the lean issue I had to back off since I don't want to damage my motor.
Old Nov 28, 2009 | 10:21 AM
It frustrates the shyt out of me that we still cannot adjust simple fuel curves with an app/programmer. IMO, this should be one of the biggest on the "to do" lists for us.....Having said that, each car is always different. Custom dyno tuning is really the way to go. Trust me, I have been having lean conditions with every tune I've had. I will be getting my dyno tune within the next week or two to resolve this once and for all (crosses fingers). Lol. I would consider this if you really want to dial it in......
Old Nov 28, 2009 | 10:29 AM
SRT6 Gang Member's Avatar
THREE 6S
If I recall correctly, Bulldoggers upgraded his fuel pump to an SL55. Unless you did the same, his tune would not correct your leaning issue, since you would not have the same fuel flow rate.
Last edited by SRT6 Gang Member; Nov 28, 2009 at 11:56 AM. Reason: Bulldoggers not Bullgoggers, Same not sme
Old Nov 28, 2009 | 02:16 PM
waldig's Avatar
Talking Re: Leaning out issues
18 is massivley wrong, you are using a uncalibrated sensor or the engine is sick lean, I get 14.2.
You can boost a/f by adjusting the fuel RAIL PRESSURE. Only takes 3-5 pounds above the stock 60 psig to turn 17 : 1 to 12:1.
WOODY
Old Nov 28, 2009 | 02:17 PM
waldig's Avatar
Did not indicate that it went, tried sending again, Sorry
WOODY
Old Nov 28, 2009 | 02:21 PM
THREE 6S
It will be interesting to see if the dyno tune corrects this leaning issue. If not, then the Tuner should be able to see and tell why.
Good luck Gent's, let us know the outcomes.
Old Nov 28, 2009 | 02:28 PM
mrphotoman's Avatar
woody where did you install your adjustable fuel pressure regulator at?
I assume you used one of these:
AEM 25-390 Adjustable Fuel Pressure Regulator
I have used this one before on other cars:
Holley 512-500-1 Ford 1986 to 1993 5.0L Mustang Adjustable Fuel Pressure Regulator 35-65 PSI - Atlantic Speed Warehouse
Old Nov 28, 2009 | 02:50 PM
Xray's Avatar
I have had the ztronic and dashdaq installed for the last month and always read about 14.8 to 15.0 at an idle. So unless the sensor could loose calibration somehow I would think it is accurate. Around town and at highway speeds it is reading 14.8 to 15.0. Is it possible my fuel filter is clogging or have these cars had any fuel pump issues?
Old Nov 28, 2009 | 04:05 PM
ZAHANMA's Avatar
if you have had idle AFR of 14.0 ish for the last few months than that is about right... what is happening if i were to guess is that thhe changing weather is causing your car to lean out at the top end... if i were to guess i'd be it is at the top of third gear...
your custome tune on 12/12 will be good for it. tony at eurocharged, myself and distantpulse will be working this week to take care of distantpulse's bit of a leaninig problem. it should give tony a good starting point for your tune once we get his dialed in this week...
Old Nov 28, 2009 | 06:01 PM
waldig's Avatar
Youd replace the stock one and adjust it as you need.Woody
Old Nov 28, 2009 | 06:03 PM
Xray's Avatar
That is good news I hope you are successful in fixing this issue. I really would like to see my car live up to it's potential.
Xray's Avatar
Woody where is the stock pressure regulator located.
Old Nov 28, 2009 | 07:32 PM
Squirrel Crusher's Avatar
I lean out also after installing the 185.. Mustang GT guys think I'm chicken. I am! Just trying to save my fuel starved engine. NeedsWings is finalizing his bench testing with the solution to our leaning out problem. Rob will be releasing his solution kit for our problem shortly. I'm sure a good back yard mechanic could solve this problem on his own,but I need a kit. Squirrel Crusher
Old Nov 29, 2009 | 11:54 AM
Xray's Avatar
Just when you think you are done spending money something else comes up. Will the fun never end?
I am looking forward to the time when I will get to just go run my car for a while with out thinking about the next mod.
Old Nov 29, 2009 | 12:12 PM
32krazy!'s Avatar
you should know by now the mods never stop!!! the quest for more power and faster times is an addiction. give in to it and accept the fact that you are now a modding madman!!
Old Nov 29, 2009 | 12:20 PM
yes, if a 1/10 you need, it takes $$$ to get it. Rob, and of course, Prof Woody are on to something...so I am standing by before I do anything else...this leaning out thing happens to me too....I haven't done any cooling mods yet, and haven't went to meth yet, but something has to happen where we are now...
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
ozkancab
Sep 25, 2015 10:55 AM
