Belt Tensioner replacement
Old Dec 10, 2009 | 07:38 PM
Buggin's Avatar
Default Belt Tensioner replacement
I know this has been covered before, but people keep saying that the "cheap" tensioner listed on RockAuto.com doesn't work. You can find it under 2002 SLK32 AMG and it works perfectly. It is the updated Mercedes part# 112 200 0970 (Old# 112 200 0770)
Differences:
- It has a plastic pulley that is a little narrower than my stock metal one.
- It doesn't use the center of the pulley to move tensioner. There is a nice 17mm "nut" on the edge of the tensioner. (Much better design IMO)
* Note: It comes with a metal pin temp installed. This allows you to access the mount bolts and install the tensioner easier. DO NOT forget to pull this pin, otherwise you will not have tension on the belt * (Yes, I'm a man of experience... lol)
Old Dec 11, 2009 | 02:19 PM
240M3SRT's Avatar
Default Re: Belt Tensioner replacement
Thanks for that info, great post. How much is the item with shipping?
Old Dec 12, 2009 | 08:09 PM
Buggin's Avatar
It was $60 shipped I believe...
Old Dec 12, 2009 | 08:18 PM
32krazy!'s Avatar
can the pulley be removed for the p/s kit or is it a permanent part of the tensioner?
Old Dec 12, 2009 | 08:26 PM
Buggin's Avatar
I didn't try taking it off, but it looks as if you can just take out the star-screw.
Old Dec 12, 2009 | 09:23 PM
MikeR's Avatar
If I hadnt just replaced mine, I would seriously consider buying one of these just for that handy tool point to use instead of the E10 bit. I have three (3) spare pulleys now too, so it will probably be a while before I have to worry about a new tensioner.....
Adrian_X
Apr 8, 2020 02:36 PM
sittininthesun
Aug 24, 2015 10:47 AM
RiderJC
Aug 11, 2015 12:18 AM
UNDER PSI
Aug 1, 2015 02:11 AM
Tp'sfury
Jul 17, 2015 01:15 PM
