Water Coolant Resevoir
Old Feb 17, 2010 | 05:13 AM
kolevski's Avatar
Default Water Coolant Resevoir
Guys does anyone know how to loosen up the water resevoir? I want to lower my car but I cant take out the top bolt because it hits the resevoir.
I just need to move it enough to I can feed the bolt out.
Old Feb 17, 2010 | 07:42 AM
maxcichon's Avatar
Default Re: Water Coolant Resevoir
Oh, yeah.
Remove the 2 M6 nuts and un-clip the hose restraints.
Remove the electrical plug at the bottom of the reservoir.
Put your hands underneath and LIFT-hard.
If you can, spray a little WD-40 or equiv. on the barb right at the bottom. It is dry and very hard to get out of the rubber grommet.
Look under it with a mirror. You will see.
Old Feb 17, 2010 | 08:57 AM
ZAHANMA's Avatar
I would also suggest pulling away from the side of the car to help accomodate the angle that the barb enters the rubber grommet at the bottom. Doing this significantly helped me when I was doing my HID install.
Old Feb 17, 2010 | 10:21 AM
BrianBrave's Avatar
<--- Huge Horsepower
A Thousand Words.....
Old Feb 17, 2010 | 05:23 PM
kolevski's Avatar
Thanks guys, its that rubber holder that gave me trouble I didnt know whether it was permenantly fixed there or not I didnt want to pull to hard incase I broke it. I want to just move it enough so the bolt comes out I dont want to unclip the hoses otherwise I'll loose all my coolant
Old Feb 17, 2010 | 05:42 PM
MikeR's Avatar
Just remove the two nuts and pull it free. You dont have to disconnect everything if you just want it out of the way some. There should be enough play in the hoses.
Old Feb 17, 2010 | 05:50 PM
OK, Brian, what are you up to? Valve covers off, large gapping hole?
Old Feb 17, 2010 | 05:54 PM
MikeR's Avatar
That was an old pic Doc... he put his shiney custom IC tank in there and polished up all his engine parts..... your memory is going man.....
Old Feb 17, 2010 | 06:02 PM
maxcichon's Avatar
BUT, if you don't disconnect the level cable, it will be a problem.
Really.
Old Feb 17, 2010 | 07:00 PM
32krazy!'s Avatar
as long as you have the resovoir up and out of the way plug off the large bottom line and the small line from the i/c. separated system!!
Old Feb 17, 2010 | 07:12 PM
kolevski's Avatar
Duno if that seperation system does anything man, the hotter my car gets at the track it puts out better times lol crazy huh?
I figure if it were that much of a big deal MB would have done it from the factory it's only a line or 2 isnt it?
BUT in saying that a few guys have seperated there systems and ran like a trunk mount system and fill it with ice or have ice around it on track days now I do believe that would definatly help.
Old Feb 17, 2010 | 08:19 PM
32krazy!'s Avatar
it most certainly helps. the hot coolant from the engine isnt being run thru the i/c. also the i/c system is low pressure and the engine is high pressure. so the sep. is cheap and an added bonus
the rear tank only helps if you are draining and refilling with ice. no matter how big a system you run, eventually all the fluid gets to the same temp as the i/c and the supercooler can only cool so much before its heated again. the more fluid just allows you to take longer to reach that point. then you have to consider the weight vs temp advantage.
brianbrave has a ton of info on this subject. check his posts.
as for running better when hot, if your just running test and tune you can stop at your convience. if your bracket racing or autocrossing for long times you will have s/c shutdown. in the us there are times when you will be hot lapping at the 1/4 and no time to cool down . then the iat's will rise drasticly
minimayhem
16
Aug 23, 2016 07:47 AM
suelo
Sep 18, 2015 05:01 PM
cppeabody
Sep 15, 2015 08:43 AM
williammt
Sep 6, 2015 11:23 AM
Ralph289
Jul 26, 2015 12:52 PM
