Does your sc still run?
Old Feb 24, 2010 | 06:00 PM
Raz83's Avatar
Default Does your sc still run?
Does your supercharger still turn on if your pump is not working?
I purchased a used pump but the sc still shuts off the same way it did with the old one kicking in and out it's getting frustrating any suggestions?
Old Feb 24, 2010 | 06:22 PM
Punkin's Avatar
Default Re: Does your sc still run?
As far as I know the SC will not work with out the pump. As to yours with the new pump.... maybe you didn't get all of the air out? The main reason for SC failure has been the pump but there are other reasons. I'm sure you will get some more feedback.
Good luck
Old Feb 24, 2010 | 06:50 PM
NeedsWings's Avatar
the s/c clutch will engage and you will get boost until the IAT's climb too high due to the IC pump not moving the fluid thru the intercooler. once the IAT's get too hot the supercharger clutch will not engage = slow car.
Old Feb 24, 2010 | 07:16 PM
the sc will turn even at idle as the air to the engine goes through the sc it will turn, slow, you can stop it with a glove on your hand ,,look at the bearing just under the sc pully and belt. jim
Old Feb 24, 2010 | 07:55 PM
robby363's Avatar
Check fuse #13 it's a red 10 amp fuse. If it's blown the pump won't work.
Old Feb 24, 2010 | 08:17 PM
70GT6's Avatar
Intake Air temp sensor could also cause similar problems.
Old Feb 24, 2010 | 08:52 PM
waldig's Avatar
Talking Re: Does your sc still run?
Consider a data logger, and be moved to other cars too.Woody
Old Feb 24, 2010 | 10:10 PM
Raz83's Avatar
Is that fuse in the engine compartment ?
Old Feb 24, 2010 | 10:14 PM
tighed1's Avatar
It's here...
Drivers side under hood.
Old Feb 24, 2010 | 10:31 PM
Raz83's Avatar
Cool thanks I have a feeling that's what it might be I'm at work right now but I'll check it out in the morning.
By the way is there anyway to rig it so the pump can stay running I know it would wear down the pump quicker but I would like to try it thanks
Old Feb 24, 2010 | 11:04 PM
robby363's Avatar
Originally Posted by tighed1
It's here...
Hey tighed1, what's the purpose for those wires you have hooked up.
Old Feb 25, 2010 | 12:13 AM
rcompart's Avatar
It keeps the SC pump on whenever the car is on.
Old Feb 25, 2010 | 12:33 AM
Raz83's Avatar
Yep turns out it was the fuse
I thought it could have been but I never checked the ones under the hood thanks again guys great!! help
Old Feb 25, 2010 | 03:05 AM
cross><hair's Avatar
Awesome news! Glad you found the culprit. SEE- this is the exact reason for being par of online car communities.
Old Feb 25, 2010 | 08:03 AM
tighed1's Avatar
Write up is here...
https://www.crossfireforum.org/forum...-pump-srt.html
rmcdaniel12
Nov 4, 2015 04:08 PM
cjw
Oct 26, 2015 10:26 PM
thatcham
Oct 5, 2015 02:41 PM
Oct 1, 2015 01:42 AM
cjw
Sep 27, 2015 10:22 AM
