I think I found it...
Old Feb 27, 2010 | 03:47 PM
MikeR's Avatar
Default I think I found it...
I have been fighting with a intermittant no start issue on the Aero for over a year. With some help from the guys here I narrowed it down to an unidentified load that was putting my voltage at under 10V when starting. I have also had a problem with my courtesy lamps in that when I have them enabled to come on when the door opens, they are always on and the trunk lamp is also on. So I have just had the switch off.
So today I decided to go find out which switch was not working and making them stay on. It was the trunk latch switch. It is broken and indicates that the trunk is always open. I unplugged the switch so now it thinks it is always closed and the courtesy lamps work just like you would want them too.
Next I got the meter out and tested the voltage when starting... 11V+!! Starts every time. Fires right off, just like it should.
Now I just need to buy a new latch... the switch is built in of course.
Old Feb 27, 2010 | 03:49 PM
32krazy!'s Avatar
Default Re: I think I found it.....
dont the small things just drive you crazy!? easier to diagnose a broken engine than a smakll electrical issue!
Old Feb 27, 2010 | 03:50 PM
Nice investigation Mike....solving the illusive no start...dang cars have way too many safe guards for me...lol
Old Feb 27, 2010 | 04:19 PM
Me too. I remember when......oh never mind.
It's always something! And always the last place you looked.
Good work there Mike.
I'll add it to the "might be this" list.
roadster with a stick
Old Feb 27, 2010 | 05:52 PM
rcompart's Avatar
That's great news Mike. Glad you got that figured out because I know it was giving you the beef for a long, long time. BTW, you get a chance to swap out that bad TB connector with the one I sent you with those washers? How'd everything go?
Old Feb 27, 2010 | 07:54 PM
hcarter's Avatar
Mike my courtesy lights stay on also all the time unless i cut the switch off what should i look for on the switch in trunk actual crack or just a bad swich and do you think this could also effect the operation of the top ???
thanks Howard
Old Feb 27, 2010 | 08:13 PM
MikeR's Avatar
Howard,
You will have to test the switch with a meter to see if it is working. Just remove the latch and manually latch and unlacth it while checking pins 1 and 2. There are three pins but only 1 & 2 get connected to the harness.
I couldnt even guess if it would affect the convertible top...
Old Feb 27, 2010 | 09:16 PM
rcompart's Avatar
thanks Howard
If the trunk isn't latched closed, the top will not operate. This prevents the trunk and the convertible cover sheet metal from coming into contact with one another.
Old Feb 28, 2010 | 12:43 AM
tighed1's Avatar
Nice troubleshooting there Mike.
Gonna have to keep this one in the ol' memory blank incase I see similar symptoms.
Old Feb 28, 2010 | 09:30 AM
Exactly.......
franklindm
Mar 14, 2020 12:23 PM
MiamiTVR
Jan 30, 2016 02:15 PM
Sep 25, 2015 02:16 AM
Selbyl
Sep 22, 2015 09:31 PM
BlackJax-SRT
Southeast Forum
Sep 17, 2015 03:03 PM
