Bosch fan(?) unit on driver side front inner fender
Old May 12, 2010 | 01:14 PM
RPatton's Avatar
Default Bosch fan(?) unit on driver side front inner fender
Yep, under the hood, driver's side, front of the wheel well.What does this Bosch fan gizmo do?
Thanks in advance for helping this SRT-6 newby with his dumb question.
Regards, Robert Patton
Old May 12, 2010 | 01:19 PM
kingkub57's Avatar
Default Re: Bosch fan(?) unit on driver side front inner fender
I think your refering to the secandary air injection pump.
Old May 12, 2010 | 01:24 PM
RPatton's Avatar
Secondary injection pump ? Sounds good to me.
Aside from comming on at cold start-up, and only occasionally, what is its function...save ,perhaps, setting a check engine light on?
Thanks, RP
Old May 12, 2010 | 02:04 PM
rcompart's Avatar
It increases the oxygen content to get the cats heated up and running quicker so the engine can go into closed loop. Kinda like EGR only backwards.
Old May 12, 2010 | 06:31 PM
daithi2's Avatar
onlything it does for me is provide the check engine light.
Old May 12, 2010 | 08:32 PM
spotsbimmer's Avatar
That's super cool that Rcompact is such a wealth of information and willing to share, I always enjoy reading his replies.
Old May 13, 2010 | 11:00 AM
RPatton's Avatar
My thanks to all that responded.
Old May 13, 2010 | 02:27 PM
RPatton's Avatar
PS...Rudy and daithi2, I noticed that the hose from the air pump was dislodged, perhaps causing the check engine light.
Thanks, again, Robert Patton
Old May 13, 2010 | 02:38 PM
rcompart's Avatar
Do you happen to know what code(s) you're getting and can you hear it cycle when you first start the car after it's been sitting awhile? unless your hose came disconnected like RPatton's, you probably have either an intermittent wiring issue or a bad air pump.
Thank you, I really appreciate the kind words.
Robert, do you have an OBDII scan tool? If you do, what code(s) is it giving you?
Old May 13, 2010 | 04:37 PM
RPatton's Avatar
Rudy, my scangauge II will not talk to the car. I've got a local shop that will scan/clear it for me.Also have all of the codes so that I can look it up.
Thanks, again, RP
michaelcycle58
Jul 28, 2015 08:12 PM
axnguyen
Jul 21, 2015 11:41 AM
ZX2 Nick
Jul 15, 2015 08:49 PM
66L72M21
Jul 15, 2015 04:23 PM
shawnwatson9493
Jul 9, 2015 11:47 PM
