Installed a Code 3 intake and code 3 Pulley (GAINED NO POWER)
Old May 18, 2010 | 01:13 AM
PA/XFIRE's Avatar
Default Re: Installed a Code 3 intake and code 3 Pulley (GAINED NO POWER)
Originally Posted by srt6power
i have a code three intake and pulley.. my good friend has a stock SRT6 we ran... i gained absolutely no power... head to head any comments?
CHECK YOUR FAN BELT AND LOOK FOR BLACK SOOT AROUND THE FRONT OF THE ENGINE,BELT MY BE SLIPPING. MAY NEED A BELT WRAP KIT.
Old May 18, 2010 | 02:03 AM
ProjectMayhem's Avatar
Originally Posted by Infinite
maybe 7.1 peak, but how much was made under the curve?
took the words out of my mouth. Maybe only 7hp more peak but you gain alot of meat under the curve which makes a big difference in acceleration.
Old May 18, 2010 | 02:10 AM
Infinite's Avatar
yep, and every modification shifts where peak power is made. Ive even see where in some situations peak power drops a bit but more power is made elsewhere, so going by peak power really isnt the way to do it
Old May 18, 2010 | 06:33 AM
mrphotoman's Avatar
Originally Posted by 240M3SRT
ROFL....o/p a c3 pulley is worth 20whp on a shitty day.
Maybe remove that dumb code3 intake, oh i mean cheesy filter at the back of the factory intake...c3 got some people good with that gimmick.
definately, if he is running that 5 cent filter on the back of his engine that just sucks hot air and hurts power.
Old May 18, 2010 | 06:34 AM
mrphotoman's Avatar
you pick up a lot more than 7hp, plenty of dynos on here for people to check out.
Old May 18, 2010 | 08:33 AM
tunaglove's Avatar
Ditch the filter, I made a copy of it and my car felt SLOWER.
Old May 18, 2010 | 10:51 AM
BLKFIN's Avatar
ADDICTED TO BOOST
You guys are all crazy....
The issue is no tune. I ran a 12.3 with tune, Code3 pulley and code 3 filter. Ran 12.2 with the code 3 filter off and needswings on. BikeCop ran the same 12.3 if I recall. I put the code 3 filter on a stock SRT6 and it picked up .2 on back to back runs. GET A TUNE!!!!
Old May 18, 2010 | 12:12 PM
BrianBrave's Avatar
<--- Huge Horsepower
+1
With plenty of sample data passes for reference - it would be interesting to see the net gain / loss when swapping out the Code3 pulley with the OEM pulley (with tune and "any" intake mod) then making a few passes.
Old May 18, 2010 | 12:30 PM
BLKFIN's Avatar
ADDICTED TO BOOST
+1
I have never done this at the track but I rode around with stock pulley, code 3 intake and a tune for a few weeks when I was thinking about selling my car. I put a code 3 pulley back on and it felt like a different car!!! The key is all these items work together to create the end result. Quite frankly, any of the 3 items... ( Pulley, Intake, Tune) no matter what brand, style or cost seem to net the same result. 12.2-12.4 in the 1/4.
Old May 18, 2010 | 03:04 PM
srt6power's Avatar
No wheel spin. we did a 40 roll second gear. head to head all the way to about 130..
Old May 18, 2010 | 03:14 PM
waldig's Avatar
Talking Re: Installed a Code 3 intake and code 3 Pulley (GAINED NO POWER)
If you installed it and have no wheel and belt slip, you have an intake leak of some such thing cause I have run all pullies and one stacked set. Youll note the difference, buttometer for sure. Woody
Old May 18, 2010 | 03:16 PM
msheredy's Avatar
Originally Posted by mrphotoman
check everything you changed...
Watch he put the OEM pulley back on. Hey crazier things have happened LOL!
I also wonder which version he purchased? Aren't there 3 different sizes floating around these days?
Old May 18, 2010 | 03:58 PM
PA/XFIRE's Avatar
[quote=msheredy]Watch he put the OEM pulley back on. Hey crazier things have happened LOL!
I also wonder which version he purchased? Aren't there 3 different sizes floating around these days?[/quote
Good point, original c3 pulley 65mm (two versions groved steel and non groved alum). Then came the c3 68mm called a midsize also two versions alum first then steel no groves either one (meant to run stacked with a 178mm crank pulley).Just my two centavo's. ILLCYA
Old May 18, 2010 | 04:32 PM
srt6power's Avatar
This is the one i bought.. the one to the right
Old May 18, 2010 | 06:05 PM
msheredy's Avatar
Hard to tell from the photo but it would appear that the one on the right is slightly larger so perhaps it is the midsized version. Do you have a caliper to measure the diameter?
Old May 18, 2010 | 06:26 PM
Mimi05SRT6's Avatar
The pulley alone gives you 4 more PSI of boost! My car went from 14 to 18 psi, so it should be the same for all of us. So I'm thinking there better be more than 7 hp from 4 more PSI.
Old May 18, 2010 | 06:27 PM
srt6power's Avatar
Even being midsized i should have some type of hp gains?
Old May 18, 2010 | 07:50 PM
  #38 (permalink)
I don't know....DJ...you keep out this....you and your black thing...but when I bought the blue coupe....stock, it would keep up with the "black" roadster...now with the same mods and "no tune" it will take the roadster out of the hole...not every car is the same...mods or no mods...this little blue coupe may be faster, but only the track times will tell....so, your friend just may have a pretty fast stock srt to begin with...but, once the code 3 pulley was put on, and installed correctly...which means proper gap set when you installed it...you should notice the difference in the lower end...for sure...I take it, you did a throttle reset, and gave the car some time to adjust?.....just my take on it...
Old May 18, 2010 | 08:17 PM
  #39 (permalink)
32krazy!'s Avatar
the 7 hp is from adding the filter to the pulley not the pulley itself. you need to measure the pulley it should be 65 mm. anything else is the midsize pulley meant to be run stacked with a 178.
check the spacing of the pulley. you may have it spaced to far out and its not engaging properly. you want it as close to the clutch without touching anywere on the clutchpack
AND DJ THE BLACK COLOR IS GOOD FOR A SOLID .2 FASTER TIME. cmon you know you want one!!!!
and lastly buggin had a c3 filter during the dyno tune session. he pulled bigger # than most of the srt-6's and 32's there. and he backs it up with a 12.1 timeslip!!!
Old May 18, 2010 | 08:30 PM
  #40 (permalink)
srt6power's Avatar
So the only way to gain power is to go purchase a 178 pulley to add on to this?
