Does your A/C get warm when you punch it??
Old Jun 12, 2010 | 06:32 PM
waldig's Avatar
Talking Does your A/C get warm when you punch it??
Before I get into the car to check for a vacuum leak, I wanted to ask the group first. When the a/C was on I happened to punch the car and the air vents went hot for 15-20 seconds.
Iam not sure if the car cuts off the compressor or if the vents closed due to loss of vacuum signal. I suspect that the car has a compressor cut out but dont know. I ususally dont have the a/c on while getting down, but this came up today.
INterested in your collective understands and experiences, thanks Woody. Weekend............
Old Jun 12, 2010 | 07:08 PM
SRT SIX's Avatar
Default Re: DOes your A/C get warm when you punch it??
Experience over the years has been that the AC cuts off if you kick down hard on every car I have owned. Because the AC pulls quite a bit of power, the cars computer assumes you must want to pass or merge. Lifting off full throttle will re-engage the AC compressor.
Old Jun 12, 2010 | 08:41 PM
MI1XFIRE's Avatar
That is correct.The compressor doesn't reengage immediately after you let off if you were under WOT for less than about 7 to 10 second.
Old Jun 15, 2010 | 08:25 AM
PA/XFIRE's Avatar
Default Re: Does your A/C get warm when you punch it??
Hey woody i read that some where in the online manual, the compressor does cut out at wot.
Old Jun 15, 2010 | 10:45 AM
billvp's Avatar
nowhere near 15-20 seconds after letting off of WOT ... maybe 2-3 seconds or so
Old Jun 15, 2010 | 01:05 PM
ProjectMayhem's Avatar
I never noticed the air getting warm out of my vents when i romp on it. Altho i never get a chance to go wot for more than a couple seconds... Police tend to get annoyed by 80+ speeds .
Old Jun 15, 2010 | 01:58 PM
Even my 98 Ford Ranger cuts the A/C out when I stand on it! (And with a little 2.5L 4 cylinder, I WOT it quite often.)
Old Jun 17, 2010 | 10:49 AM
02C32guy's Avatar
I've read about a clutch that disengages the AC under WOT. With that being said, I've done this plenty of times in the recent heat and haven't noticed any warm air afterward.
Old Jun 17, 2010 | 04:37 PM
waldig's Avatar
Talking Re: Does your A/C get warm when you punch it??
I have the 185 pulley and when I go to the floor the air coming out goes hot hot real fast like 2 seconds and wont cool again for 3-6 seconds in coast mode. Iam wondering if the vacuum system is losing its stored vacuum and allowing the doors to revert to the uncontrolled "open" position, causing the issue.
Wondering woody?????????????????
prototype fuel boost controller with lots of gauges for watching...............
Old Jun 17, 2010 | 11:28 PM
Tested this today and went wot for about 4 seconds and the air stayed cold(ice cold)
Old Jun 18, 2010 | 09:38 AM
tunaglove's Avatar
I had the same problem after I removed the rubber strip gasket between the hood and the wipers. Look, the hot air from the engine can go right into the vent intakes.
Old Jun 19, 2010 | 04:42 PM
turtlesdove3's Avatar
Anymore info on the clutch?
Valk
Jul 12, 2021 09:49 PM
minimayhem
16
Aug 23, 2016 07:47 AM
debradegiovanni
Sep 27, 2015 09:39 AM
atdavis2
Sep 21, 2015 01:25 PM
BEATv1
Sep 10, 2015 12:58 PM
