my engine broke down
Old Jul 12, 2010 | 11:43 AM
Rasim's Avatar
Default my engine broke down
Hi GUYS, last time i had 2 problems with intercooler and transmission and resolved them, and now finally i found my engine dead, the block of cylinders is damaged got a big scratch that is not able to polish.
I decide to shave 3mm of the cylinders to a bigger size then put 3mm cartridge-case and back the cylynders size diametr to stock, with losing the scratch , did any one from has ever done it on your cars?
Old Jul 12, 2010 | 12:03 PM
apkano's Avatar
Life is random...so am I.
Default Re: my engine broke down
Originally Posted by Rasim
Hi gays, last time i had 2 problems with intercooler and transmission and resolved them, and now finally i found my engine dead, the block of cylinders is damaged got a big scratch that is not able to polish.
What did you just call us?
Old Jul 12, 2010 | 12:20 PM
JHM2K's Avatar
LMAO!!!!!!!!!!!
Old Jul 12, 2010 | 06:07 PM
32krazy!'s Avatar
rasim contact ttmotorsports.com these guys do high end work on high end cars. they can give you all the info you will need
Old Jul 14, 2010 | 12:31 AM
Rasim's Avatar
do not you ever had problem with the block of engine cylinders? i need to know how to polish the scratches on it?
Old Jul 14, 2010 | 10:35 AM
Back in the old days when we had to get out score marks we used a hone and a counter balanced electric drill on a pulley.
Kind of crude but so were we. It did work and it was cheaper than having it done professionally. We cut of any lip made by wear.
I do not think I would do this on our engines, get it reground and fit new rings, maybe even pistons, depends on amount of metal removed. It may be better to get a new engine depends on your mileage.
Old Jul 15, 2010 | 11:31 AM
dinasrt's Avatar
As you may know, this is not a typical problem that occurs with normal wear. How many miles on your engine? And do you know the cause of this failure? Bob
RiderJC
Sep 7, 2015 11:19 PM
MickeyNasty
Sep 6, 2015 08:29 PM
xfClifford
Sep 6, 2015 08:20 PM
ldare2000
Aug 17, 2015 09:41 AM
Tp'sfury
Aug 13, 2015 08:20 PM
