Help! Question regarding my I/C pump replacement
Originally Posted by 32krazy!
you dont have to take the bumper off. remove the pass. wheel and then remove the front inner fender . its about 6 or 8 screws and bolts. once its out you have a ton of room to work in. also the oem clamps suck so just twist them off and replace them with worm clamps
That's what I did. But the OEM clamps were a beotch to get off. "Twist" them off sounds more simple than reality. As they are positioned now, the tabs to grab them with the pliers are turned such that I'm working blind. I may give it a second shot tomorrow to see if I can rotate them to get my pliers around their tabs.
i had no intention of reusing them. slip a scredriver under the clamp and pry up it will pop the oem clamp. if that doesnt get it the space made with the screwdriver will allow a pair of wire cutters to slice the clamp off. since i did want then on i was just brutal with them!!
LOL! I have no intention of reusing them either. I was getting so aggravated that I was tempted to cut the hoses off just above each clamp. But I knew better. I'll give it another go tomorrow. Thanks for your help & support.
BrenLW
Aug 5, 2015 04:53 AM
Jul 24, 2015 07:57 PM
axnguyen
Jul 21, 2015 11:41 AM
