Was about to install code 3 until
Old Sep 11, 2010 | 09:54 AM
Holycrap's Avatar
Default Was about to install code 3 until
i realized shims are needed. The directions from Code 3 performance indicates to use the shims provided. I bought this used and dont have any shims. Didnt even know i needed them. Im assuming the seller should have provided it. soooo where can one purchase these shims???
Old Sep 11, 2010 | 10:46 AM
ImportLabSRT's Avatar
Default Re: Was about to install code 3 until
PM me your address, I have a set of Code 3 shims Ill send you
Old Sep 11, 2010 | 10:58 AM
Holycrap's Avatar
awesome! pm sent
Old Sep 11, 2010 | 11:11 AM
velociabstract's Avatar
Mine didn't need any shims. Do you know which generation Code 3 you have? (I guess it's better to be prepared ... just in case you need them)
Les
Old Sep 11, 2010 | 11:34 AM
I will shipped out Monday
Old Sep 11, 2010 | 12:23 PM
32krazy!'s Avatar
you need to install the c3 you have, torque it to 20 nm and check to see if the clutch touches the pulley anywere. if not your golden . if it does thats were the shims come in to play. you want the pulley as close as possible without touching anywere. some use 1 shim some none some 4. every pulley seems to be different. i dont know which gen pulley you have but the early models used shims the last gen needed none.
2005 Ragtop
Apr 25, 2016 05:09 PM
umpqua rafter
Aug 24, 2015 09:06 AM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
Aug 5, 2015 12:52 PM
bdh
Jul 9, 2015 09:40 AM
