Replacing the IC Pump with CM30P7-1 Johnson Pump
Old Oct 4, 2010 | 10:45 AM
Mark Bezner's Avatar
Default Re: Replacing the IC Pump with CM30P7-1 Johnson Pump
I, too, have to confront the IC pump replacement issue on my SRT6 in the near future. I notice that Johnson sells two versions of the CM30P7-1: one with 16mm fittings and one with 20mm fittings.
Which is the appropriate one for the SRT6?
Old Oct 4, 2010 | 11:04 AM
taz2005's Avatar
Hi Mark
In the manual that came with the pump (which I ordered from Eurcharged to make sure I got the right one) it says
CM10P7-1 has the 16 mm connection and
CM30P7-1 has the 20 mm connection. (One I got for the SRT-6). There are 2 different types of the CM30P7-1 noted in the manual but the difference is voltage 12V or 24V not connection size. Hope this helps.
Old Oct 4, 2010 | 04:49 PM
loungn14's Avatar
Originally Posted by taz2005
Hi Mark
johnson just recently came out with 3 different versions of the cm30. 12v .625 fittings
12v .75 fittings
24v .75 fittings...
middle is what you want.
Old Oct 4, 2010 | 11:12 PM
taz2005's Avatar
Thanks Jake. So is Eurcharged selling the middle one? Since 20 mm = 0.7874 inches and 0.625 inches = 15.875 mm
Old Oct 5, 2010 | 09:46 AM
loungn14's Avatar
yup, but since we have put more meziere pumps on then johnsons lately.
Old Oct 15, 2010 | 12:38 PM
WES7622's Avatar
Nice job on the directions. I have a question for anyone who might know. What are the hose sizes on the pump? I found a source for the pump but they have two CM30P7-1 models. The difference is the size for the hoses. Does anyone know what size the hoses are? In mm of course. Thanks
Old Jan 8, 2011 | 10:31 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Great write-up!!!!!
New pump sitting on the bench eagerly waiting for it's turn.
Old Jan 8, 2011 | 11:24 AM
taz2005's Avatar
Thanks, I have gotten so much great help and information from the wonderful people on this forum, it was my turn to return the favor. Good luck with your replacement.
Old Jan 8, 2011 | 04:22 PM
Flightmedick's Avatar
Just got mine,
Smaller than I thought it would be
TWSS
Old Jan 8, 2011 | 08:40 PM
LantanaTX's Avatar
Do these pumps help intercooling performance or just last longer?
Old Jan 8, 2011 | 09:19 PM
32krazy!'s Avatar
different discussions on the flow rates between the cm30 and oem bosch. typically it lasts longer than the bosch. real i/c performance can be had with the supercooler
Old May 21, 2011 | 09:39 AM
kluhbah's Avatar
I am in process of replacing my pump. Does anyone know where to connect the vacuum hose off the old pump?
Thanks
Old May 21, 2011 | 09:46 AM
kluhbah's Avatar
oops, my bad, I just found the thread explaining it was not needed with the new johnson pump.
BrenLW
Aug 5, 2015 04:53 AM
Jul 29, 2015 06:13 PM
Beeker
Jul 20, 2015 03:46 PM
Tp'sfury
Jul 17, 2015 01:15 PM
