IC Pump?
Old Nov 5, 2010 | 08:35 PM
lacerdaschoon's Avatar
Default IC Pump?
On my way home from work yesterday i noticed a big loss of power when I stomped on the throttle. I released and tried again with the same result. The sc wasn't engaging. I've learned so much from u guys so immediately I thought ic pump because of these symptoms, I would have lost it if it wasn't for this forum. I just want to be sure it is infact the ic pump? Today it was fine then spontaneously I got the same issue. Is this a matter of time before it completely gives up because itt sure seems like it. Is it safe to continue driving until I replace the pump?
Thanks guys
Old Nov 6, 2010 | 04:33 AM
robby363's Avatar
Default Re: IC Pump?
Yup, sounds like it's time for a new IC Pump. It won't hurt anything driving it except for your pride. . Also check fuse#13 before you replace the pump just to make sure it's not the fuse.
Old Nov 6, 2010 | 04:36 AM
I would say pump as well...sometimes the temp sensor can go as well....but, usually it is just the pump...
Old Nov 6, 2010 | 05:49 AM
Yes you got that right my pride is well gone when i couldnt even over take a camry.. It seems to be engaging 50% of the time and seems to engage more often if i feather the throttle. From higher speeds no sc at all
Thanks for the heads up ill get that checked as well
Old Nov 6, 2010 | 05:54 AM
if it is kicking in and out, it is definetly the pump....once it cools a little it will engage...once she heats up, it disengages....
Old Nov 9, 2010 | 07:38 PM
drew_o_o's Avatar
My symptoms were exactly the same. Just replaced my pump last week. Problem solved. Needswings has the IC pump you need. Just switch the top cover with the inlet/outlet. Rob was great to deal with.
Drew
Old Nov 10, 2010 | 09:14 PM
gedwar1's Avatar
My SRT-6 is doing the same thing but less frequently. After 20 minutes of driving it will have a dramatic loss of power that lasts for about one minute. Under harder driving or hot weather conditions it will happen a little more frequently. I got an IC Pump in the mail today from Needswings. That should fix the problem. Before ordering the IC pump, I replaced the inlet air temperature sensor and the EGR transducer valve. The inlet air temperature sensor did zero to help but it only cost $36.00 from Mercedes. I replace the EGR transducer valve because it had that error code; didn't fix the main problem but made the car run smoother - so it needed to be replaced. Good luck.
Old Nov 10, 2010 | 11:55 PM
AlbertFattal's Avatar
Mine is doing the same thing, There is a DRAMATIC loss in power thats is intermittent about half the time. I suppose this is the fix!
Old Nov 11, 2010 | 02:28 AM
If you didnt know anything about cars you would think something really serious had occured to have such a drastic change in acceleration. Good to know these engines are bullet proof and at the end of the day its just a sub 200 dollar fix and your good as new. Its still the best car i have ever owned by a long shot. .
Old Nov 12, 2010 | 07:28 AM
Blast Chamber's Avatar
Almost certainly. I just replaced my co-worker's IC pump at 24,000 miles. His symptoms were exactly as you describe. Once warmed up, there was a huge loss of power during acceleration about half the time. I put in a Johnson pump and it now runs like new again.
Old Nov 12, 2010 | 07:34 AM
FUBU's Avatar
Any part# and prices? $200?
Old Nov 12, 2010 | 09:23 AM
Here is where I bought mine from. Part # 10-24504-03.
Auto Performance Engineering - Johnson CM30P7-1
Old Nov 12, 2010 | 07:26 PM
Check out Needswings.com and eurocharged.com They both supply IC Pumps
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
tritongreen
Sep 18, 2015 07:32 AM
81's
Sep 13, 2015 04:34 PM
